Old 05-29-2002, 10:27 AM   #1
tim m
Brake adjustment
How do the rear drum brakes adjust? Is it with the parking brake, or driving in reverse and putting on the brakes. About every 2 months I have to take the drums off and readjust them.
1970 k10
1971 C10
Gilbert Az
tim m is offline   Reply With Quote
Old 05-29-2002, 02:00 PM   #2
Sheenanny
Either method will adjust the brakes. Do which ever is most convenient for you. Every now and then I hold the E-brake release and pump the e-brake, then sometimes I brake hard a couple of times as I'm backing out of my driveway.
Sheenanny is offline   Reply With Quote
Old 05-29-2002, 04:31 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
they should self adjust everytime you make a rear stop, if they dont then you have frozen self adjustor theads, you need to remove the drums and remove the adjusters and break the thread sloose and take them apaprt and clean the threads and use some antisieze on the threads
Fast68Chevy is offline   Reply With Quote
Old 05-29-2002, 10:29 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Plus I find that backing with a light but firm pumping motion gewts it done the best. It'll only turn a litte each tiem you hit the brakes, so multiple pumps can help.
Old 05-30-2002, 02:03 PM   #5
Stout72
Not my good side.
Stout72's Avatar
Your adjusters are probably stuck, or else the teeth on the adjuster wheels are rounded off to the point where the lever isn't engaging, slipping off the teeth.
72 Chevy K20 Custom Camper, 350/350, 4" lift, dual shock suspension front & rear. Daily driver and a work in progress.
00 Suburban LT
90 Camaro RS
79 Yamaha XS1100 Special (Ol' Reliable)
Stout72 is offline   Reply With Quote
