Old 02-08-2005, 04:01 PM   #1
Daubs
Daubs's Avatar
Grinder (and attachments)?
I know I will need to buy a grinder. What size / RPM / etc. should I be looking for?
What about attachments? Seen quite a few on Eastwood web site (taking off paint / rust / grinding down welds) Any suggestions on what works well and what to avoid would help a bunch. Thanks.
'72 Chevy K-20 Crate 350, SM465, 4.10's
Daubs is offline   Reply With Quote
Old 02-08-2005, 04:17 PM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I got an "el cheapo" Black and Decker 4.5",10,000 rpm(max) grinder and It's taken what I've thrown at it so far.
As far as "attachments" go get various grit "flapper disks, a couple grinding disks and about a 10 pack of cutting wheels.You go through the cutting wheels pretty quick.
Oh ya,don't get that stuff through Eastwood.Your local hardware store or welding shop will have all you'd need.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 02-08-2005, 07:57 PM   #3
bigcdawg99
I bought an "el cheapo" at Harbor Freight. I don't know if there's one in your area. I don't even know what RPM (I'm at work). Grinds the hell out of everything I've tried. And yes, you will need lots of cutting wheels.
71 GMC Shortbed Fleetside (under construction)
"I like guns. You got a gun, you don't have to work out."
Chris Rock
bigcdawg99 is offline   Reply With Quote
Old 02-08-2005, 08:08 PM   #4
longnlow72
longnlow72's Avatar
i got my ryobi 4" grinder at home depot for $25, get a few grinder discs, cut off wheels, i plan on trying out strip discs and the "flapper" discs for finishing welds down
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done...
longnlow72 is offline   Reply With Quote
Old 02-08-2005, 08:30 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Honestly, there isn't a real good grinder made anymore. All of the name brands have gone overseas for manufacture.
I buy name brand ones a still go through 3 or 4 a year. Some other weldors tell me Metabo is the best available nowdays and will last for a long time. I haven't found any place local that sells them though, so I keep smoking Dewalts frequently.
Old 02-08-2005, 08:42 PM   #6
I have a 4" small shaft Ryobi and a large shaft 4 1/2" Black & Decker. I typically use the 4" with cutoff wheels for tighter places and use the 4 1/2" with flapper disks and grind wheels, mostly the flapper disks. Both seem to be holding up real well for me, about 2 years on each so far.
