Old 02-08-2005, 09:40 PM   #1
sledgehammer
Question rear axle swaps
i just bought a 68 c10 that has coil spring rear end, i also have a 71 c10 for parts. question can i put 71 leaf spring rear end under 68 with out too many mods or maybe axle swap easier?? want to go to 5 lug setup. first time poster long time reader.
hammer
sledgehammer is offline   Reply With Quote
Old 02-08-2005, 10:36 PM   #2
TRUCKGUY
TRUCKGUY's Avatar
71 c10's didnt have leafs did they?
Dan.
55 F100 panel truck project
64 350/th400/10bolt short fleet
66 F100 302/C6/9" short fleet
67 IH 4x2 304/t984speed D44 373 locker lwb box
67 IH 4x4 304/t98 4speed/d44/d60 4.10'slwb box
67 IH Travelall 4x4 304/t98 4speed/12bolt/10bolt
81 2wd short fleet current build!
83 350/700r4 short fleet
88 k5 12" lift 3/4 ton swap mud toy
96 Dodge 3500 CUMMINS/5speed/4x2
97 Pontiac Trans Am WS6/LT1 383/6speed/T-tops
TRUCKGUY is offline   Reply With Quote
Old 02-09-2005, 12:08 AM   #3
djracer
djracer's Avatar
I'd try to just swap just the axles. I prefer the trailing arm setup!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 02-09-2005, 01:23 AM   #4
70short/step
70short/step's Avatar
Some did, some didnt. The 71 axles are too long to put in 68 housing. You can cut the spring pads off the 71 and weld new pads for the coil springs. Look around your area. You maybe able to find someone to trade for a coil rear end.
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 02-09-2005, 01:28 AM   #5
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
on the early classic enterprises web site they have conversion axels you can buy also, not sure the price though
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 02-10-2005, 09:16 PM   #6
sledgehammer
thanks guys for the responce from all. I`ll get er figured out. about the leaf springs in the 71 i have a 71 lwb thats a dailey driver and a 71 lwb parts truck and the both have leaf springs under them.
again thanks
sledgehammer
