02-09-2005, 03:53 PM | #1 |
driving is in my blood
headlight and turn signal problem
Im having a problem with my passenger side headlight. It started a couple weeks ago when my drivers side turn signal indicator came and stayed on with the headlights on. It only goes off when the left turn signal is engadged, then it acts normal. I found my drivers side turn signal bulb out, so I replaced it. This made the drivers side indicator turn off back to normal, but then the passenger side one came and stayed on. Again, same as drivers side, I found the bulb out. I replaced it, but the passenger side indicator is still on. Also, my passenger side headlight is hardly putting any light out at all. I put a new one in, no change. I checked all the wiring by the headlights, everything looks ok. Any ideas on what could be wrong?
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
02-09-2005, 04:16 PM | #2 |
Professional Beer Tester
Sounds like you might have a ground problem. Check the ground wires that bolt up to the radiator support, I think there are some on both sides. Make sure they are clean and tight. Hope that helps.
60-66 Nut
60 Ford F100 Custom Cab 61 Apache Short Fleetside 64 C10 Short Stepside 65 C80 409 V8 5spd(X-Firetruck) 83 GMC 350 Olds Diesel 85 GMC Short Bed 86 GMC Short Bed 90 GMC R3500 Crew Cab 92 GMC 1500 |
02-10-2005, 12:25 AM | #3 |
Pick up man
do both inside turn signals come on when u hit the brake??
cb
heres sum pics of my truck 82 silverado c10 heres my baby 1990 k1500 check out this 1957 chevrolet for sale |
02-10-2005, 01:14 AM | #4 |
Also check the ground wire in the driver side rear tail light behind the assembly.
Real Trucks are Built not Bought Building: 1981 GM SB LowRider 1985 GM K3500 3+3 1981 GM K2500 SSB 1980 GM K2500 X-BC Hydro 1979 GM K3500 3+3 1976 GM K5 Blazer 1970 Custom 10 http://bc4x4.com/ |
02-10-2005, 01:44 AM | #5 |
No, neither lights come on during braking, but the right side one is always on unless the turn signal is engaged.
02-10-2005, 03:37 AM | #6 |
Pick up man
u might wanna check ur emergency flasher nob make sure its off cause i had a similiar prob when i first got my truck and u might wanna check the flasher in the fuse box
hope it helps cb
02-10-2005, 08:28 AM | #7 |
Dig up your wiring diagrams and Ohm out your headlight switch. Or just replace it to see if that changes things (about $10-15 if I remember correctly) All kinds of goofy lighting issues can occur if your switch is going bad as all power for the dash gauges runs through it if you trace the wires back.
