Not too old to learn
Center link needed
Looking for manual center link to replace ram power steering on my 68.
I believe it should be a 69 or 70 to fit correctly. Pic shows 21 1/2" between tie rod mount holes. Anyone in So Cal? Chris
1968 C10 a way to long restoration. |
Here is pic of ram system that I removed.
#3 | |
Bloo
ive got a 1970 manual steering center link.... $35 obo plus shipping
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
What is the difference between manual and power centerlinks? Sorry for intruding on the thread...
The Ram assist System (Vette style) has the control valve threaded on to the end off the center link, and the pitman arm ball stud is reversed!
Can't ya just remove the ram part and keep the original center link? I'm not familiar with the ram setup though. Am I missing something?
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
Thanks I think you guys are on to it.
I'll strip the ram piston off and see how it line up. tmad: I got a ps box out of a 70 and will try your suggestion of bolting to frame. What kind of spacers did you use? Chris
Still looking for center link in Southern Calf. I had a call but was the wrong one.
I need to see it. Also need the shaft coupler (some call it a rag joint) Must be for power steering box a mnual won't fit different diameter shaft.
