Old 02-09-2005, 06:56 PM   #1
69 longhorn
seat time....
I have been running Jazz plastic buckets in the longhorn.....Im ready for a change! I am looking at the early 90's PU bench seats (nothing fancy) just a good old veloure seat. i need a little advice on fit.....beaering in mind that i could have shifter handle issues(6 spd richmond, sb, in i 6 spot). crazyL
69 longhorn is offline   Reply With Quote
Old 02-09-2005, 07:14 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
The 70 Swb I Sold To "GenIIIshorty" Had A 3spd In It, Now
Converted To 350 Automatic, Here's A Pic Of The 90 Model
Bench Seat That I Installed In Mine When I Got The Truck
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-09-2005, 07:38 PM   #3
Blue_71
Bloo
Blue_71's Avatar
i put an 89 bench in my k20 just like that one, but i had to put 1" spacer blocks under it to make it comfertable... i also had to drill 4 new holes in the floor... i'll try to get pics tomarow if its bright enough out
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 02-10-2005, 01:59 PM   #4
69 longhorn
If the gas tank is out of the cab.....will the seat slide back a little more? I need to keep it as low as possible, due to a 4" chopped top.... L
Old 02-10-2005, 03:46 PM   #5
Crazy
If you mount it into the factory front holes, you'll need a 1" spacer for the rear mount and have to drill a new hole for the rear mount. In your case, I would use the late model bracket slid back to where it will mount flat on the floor. You'll need 4 new holes, but it will sit approximately the same height as a stock bench, maybe a hair lower.
As far as front to back movement, the top of the seat hits the cab ridge before the tank , so it would be a very minimal, if any, amount of extra space that the removed tank would give you.
Check my site and it'll make sense. I used the stock front mount holes.
Old 02-10-2005, 05:12 PM   #6
69 longhorn
thanks guys I may have to notch the seat, or build a "boomerang" shift handle to fit......just looking for a smooth ride out on the open road .... L
Old 02-11-2005, 04:19 AM   #7
4x4Poet
Yeah, 69l, keep that Richmond 6-speed limber at the stick.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
