I'm watching you!
Looking for trailing arms and left window reg?
Hello,
I am new to the forums here and a new truck owner. I just purchased a 1968 C-10 2wd lwb pickup. Got a good deal on the truck but need a set of trailing arms to "safely" drive it. The left arm you can see the other half through and and the right one is not much better. I am kind of on a limited budget right now and any help finding these will be appreciated. Also the left window is playing auto down. Is this the regulator that is bad? If so any of those out there? Also does anyone know the correct tires size for these trucks. All the tires are just about bad and they are all different sizes. The rims are 15" 6 lugs. Thanks, Mike Last edited by 68haywagon; 02-09-2005 at 08:53 PM. |
![]() Join Date: Nov 2002
Welcome to the Board from the NorthWest. I have a parts truck with trailing arms but getting em there would kill you. You'll find someone closer to buy from, on the window regulator buy a new one from a board vendor, those things wear out since the drivers side window gets opened alot more than the pass. side...Tires.....whatever will fit and whatever you can afford, just make sure they're not split rims, you's wanna throw them away B4 some gets hurt.
try burnsman
brian should be able to fix you up good . he is in pa so even if you needed to ship it wont kill you . Tell him todd from the board sent you , on second thought he may charge you double
