Old 02-10-2005, 02:14 AM   #1
muddpile
muddpile's Avatar
New wiring harness worth it?
I was looking at my old 72 today, getting ready for the teardown, and I noticed that the 30 year old wiring looks pretty bad. It's not bare or cracked that I know of, just looped all over the place, spliced, etc. Since I am doing a frame off anyways (or the better part of one for sure) should I replace the whole setup? My truck is low options and will stay that way. It has power steering, manual brakes, column shifted auto, no air, extra gauges but no tach, and the engine and HEI out of an early 80s suburban. Is it worth it to get a new harness, or should I just try and sort the old one out and tidy it up a bit?
Also, how hard is a new harness install, and what one should I buy? Thanks!
muddpile is offline   Reply With Quote
Old 02-10-2005, 04:22 AM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
depends on your finaces.
Wireing is the blood of your truck,without it you'll have plenty of problems.
I personnally would bite the bullet and buy a new harness.
30 year old wiring is a fire hazzard as well.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 02-10-2005, 10:31 AM   #3
GreyHoundSteve
I decided to go with a new painles harness and im glad i did. The wiring on my truck was in about the same condition as you described yours. The original wires were in decent shape but alot of them had been spliced by the po's and i was getting shorts so i decided to pull it since i was doing a frame off. The new harness was an easy install and looks great. It also has alot of updated provisions and while you may not plan to add any of these options now you might change your mind later and even if you dont youll have plenty of extra space fo anything else you might want to add in the future. If i ever do another one of these trucks the old harness will be the first thing to go again.
GreyHoundSteve is offline   Reply With Quote
Old 02-10-2005, 11:16 AM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
If you have to ask, then the answer is YES.
I have replace all my underhood wiring, except for the A/C specific harness, since I am not using the A/C at the time...pending the paint job on my truck.
Go to www.wiringharness.com for the website for M&H Fabrication. They make reproduction harnesses and can modify them for 1-wire alternators or HEI distributors. The color code is as new, and all connectors, brackets and covers are already in-place.
I liked dealing with them, better than someone like LMC. LMC is just a jobber and knows very little about what you are ordering. M&H builds them and you can call them and ask all kinds of questions.
Member Nr. 2770
Old 02-10-2005, 12:51 PM   #5
gabet40
ya especially if ur already doin a frame off. gonn have to tuck n route all the wires anyway, might as well make em nice new ones. ive heard those r pretty easy to install anyway
Current owner of 2016 2500 Silverado Midnight Edition.
Former owner of:
69 1/2 ton, change from long/fleet to short/fleet, shaved door handles, shaved tailgate, 4/6 drop, power windows, 700r4
72 blazer, 350 with Holley Commander 950 DFI, crane energizer cam, 350 tranny, dual sanderson blockhuggers/magnaflow exhaust
gabet40 is offline   Reply With Quote
Old 02-10-2005, 01:19 PM   #6
tkeduk8r
tkeduk8r's Avatar
I chose to go with a new harness for an engine swap I did in our 68 skylark ragtop, and it was the best 150 bucks ive spent for restoration anything... I bought through year one, but it was an M&H as previously discussed... I tore alll the old spliced, broken, rotten harness out and routed the new one with the instructions and factory chassis service manual and it rocks.. lights are brighter, more powerful spark, better fuel milage and its all correct under the hood now... highly recommended.. im not even thinking about using the stock harness on my 70 resto!!! hope that helps..
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 02-10-2005, 01:28 PM   #7
4LUG39
I used an E-Z wiring I bought off E-Bay on my 39, It worked great. This is after wiring my 54 on my own, That was not smart. Save time, money and piece of mind.
Ain't no way in the world I'm going out that front door.
69 SWB Fleetside 327/5spd
76 blazer 383/700R4
95 2Dr Tahoe 5.7 4x4 LT
4LUG39 is offline   Reply With Quote
Old 02-10-2005, 07:44 PM   #8
BOSS
Just here to help
BOSS's Avatar
I chose to just fiz the wiring in my 4x4 and if i had it to do over again i WOULDNT!!!!! Now i am haveing problems everytime i turn around and still dont have it all fixed yet.Save yourself some time and heartache and get a new harness.I know i wish i did.
BOSS is offline   Reply With Quote
Old 02-10-2005, 08:03 PM   #9
mac
Active Member
mac's Avatar
I put a RON FRANCIS 12 circuit in my '67 and it was the best money I've spent. I welded up all the pass thrus to the engine compartment and ran everything south and hidden. Sure cleans up under the hood. Behind the dash can be loomed up as you wish. I put in a VDO instrument set and bought a gage harness from them too. The extra $60 makes it all pretty and professional looking and if anything ever needs to get redone, its slick and easy. The one thing it didn't give me was a new wiper harness. I fab'd one using the original plugs and wire colors.
mac is offline   Reply With Quote
Old 02-10-2005, 09:36 PM   #10
Blue_71
Bloo
Blue_71's Avatar
i redid every wiring harness on my 69.... completly rebuilt each one from may-as-well-been scrap, to working stock harnesses... had to rewire in the radio and speakers too... it was scary what all i found in there, but everything works now except for one light that i didnt rewire, and one that has a blown bulb
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 02-11-2005, 02:49 AM   #11
muddpile
muddpile's Avatar
Well, here is what I've got. I've made myself a comprehensive list:
(1972 chevrolet LWB)
-Headlights (will be upgrading to better)
-Taillights (will be going with ECE LED's)
-Marker lights
-Instrument cluster
-AM radio (won't need to be hooked up, just there for looks)
-Wipers
-Interior Light
-Heater and no air
-CD deck (will be installed in glove box)
-HEI (already installed and working, but like I say, questionable install all around)
I may have missed some stuff, but that looks to be about it. What harness should I get? I have always heard good things about Painless. Are they worth doing? Also, Are there terminals on these new harnesses, or how would I go about attaching the new wires to the old parts such as gauges, lights, etc? Thanks for the help so far! It looks like this is a very worthwhile thing to do. Another bonus I noticed is that the new harness comes with a fuse block for the nicer plastic fuses.
Old 02-11-2005, 03:27 AM   #12
4x4Poet
I've seen a Ron Francis wiring harness. Each wire on it has what the wire goes to written on its respective casing every 6 inches or so all the way to the end connector/terminus, so you always know what wire/circuit you're dealing with when you're away from the fuse block originating point. Good feature. I would probably still use an M&H harness myself since it fits like oem and because I don't need much special. Maybe things will change with my K20 rebuild.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
