Location: Bondurant, IA but in Worcester, MA for school
Edelbrock intake differences???
Whats the differeence between an Edelbrock Performer intake, Performer RPM intake, and the Performer RPM Air-Gap intake??? I dont know which one I want to get. Any info would help. THanks
What RPM range the manifold will affect power in most. (I believe)
There is 2 versions of the air gap also. I think the models with RPM after them affect power in the Mid to High RPM the others are from Idle to Mid. Edelbrock has a web site: www.edelbrock.com
Rod Childers '71 C10 Stepside |
Suburbans RULE!
The Performer intake is rated from idle to 5500 rpm. This intake is good for stock to mildly modified engines.
The Performer RPM and Performer RPM Air-Gap are both rated from 1500 to 6500rpm. Edelbrock claims that the circulating air around the runners of the Air-Gap will contribute to a cooler intake charge AKA more power. These intakes should be used on engines that have been modified with aftermarket cams, heads, exhaust etc. I am running a Performer RPM on my stroker motor. ![]()
--Ben 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's. Last edited by Beast388; 05-29-2002 at 03:46 PM. |
unless you chnage your cam and have roller rockers put in,.....your probably better off with the stock thermoquad.....I love these stock intakes.....they just look ugly
![]() Join Date: Dec 2001
there is a regular Performer air-gap as well.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
its all about the +6 inches
thermoquad??? I KNOW you ain't talking about the plastic dodge carbs from the 60's.
As for keeping stock intakes, naaaa, scrap them. Even on a bone stock, points ignited engine, the performer will wake it up right off the line. If you put an RPM intake on a stock engine, it'll fall on it's face. |
Got big-block?
![]() Join Date: Jul 2000
I've used both the Performer and Performer RPM on several different engine combo's.
IMO the Performer is just a little better than a stock intake, while the Performer RPM is MUCH better than a stock intake - both in torque and horsepower. IMO, if you're running anything bigger than an "rv" cam, you should go with the RPM intake. Why? Because most people "over-carb" instead of "over-intake" a motor, resulting in sluggish off the line performance. They slap an RPM intake with a 750 cfm carb on a stock/mild 350 then wonder why it doesn't perform right. Put a 600 cfm carb on the same combo, and it will perform great. Just my 2 cents. SC
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
I need another Barley Pop
Couldn't have said it better myself SuperChevy!
67 Short Fleet 4x4 04 Honda CRF450R 89 Toyota 4-Runner 34 Ford 2 door sedan - Long term project ---------------------------------------------- There is a very fine line between "hobby" and "mental illness" ![]() |
My engine is pritty much a stock 350 but I do want to do more later to it. I dont want to have to go get another intake when I do more to it. So would I be ok with Getting a Performer RPM Air-Gap intake with a 1406 Edelbrock carb for now? Will is suck that bad. Please let me know
"TRUCKLESS"
I had a truck that had a 350 .060 over. Stock heads, Performer Rpm Air Gap intake and a 750 edelbrock (1407). That thing ran it's balls off. Of course it had 4.10 gears also, but it ran great!
Mitzki5 No longer have an old truck! But always looking for another one! |
Got big-block?
HOTROD929, you'll be OK for now with that combo.
You shouldn't see a big drop-off in low end torque, and you have plenty of intake left for future upgrades such as cam, gears, etc. If you don't have them already, throw on a set of headers while you're in there. SC
