Old 05-29-2002, 02:58 PM   #1
68 Suburban
68 Suburban's Avatar
Rear Sway Bar Question?
Looking at how these are set up, don't they affect the rearend travel quite a bit? Is this the point? lol
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 05-29-2002, 02:59 PM   #2
68 Suburban
I guess what I am worried about is the regular suspension travel in straight aways going over bumps.
Old 05-29-2002, 03:03 PM   #3
Low69CST
I've never heard of suspension travel being a problem. They been using them in so many different cars and are now being installed on late model 4x4 trucks, I don't think it would cause a problem.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 05-29-2002, 03:06 PM   #4
68 Suburban
I would think it would be a rougher ride. Also, what about when loaded down in the back?
Old 05-29-2002, 03:12 PM   #5
Low69CST
yeah, your truck will ride rougher, but if your going to be hauling a heavy load its going to give you more contol by keep your weight from shoving the back of the truck around as much. this will make it more stable and safer.
when I first got my license all i drove was stuff made just for cornering, with all the stiff springs and big swaybars. Stuff like that rides about like a tractor, but its damn sweet cutting corners
Old 05-29-2002, 04:23 PM   #6
Fast68Chevy
Fast68Chevy's Avatar
over straight bumps the bar will pivot in the two center bushings, if you look at one under a truck and study it you will see how it works., it only binds when the truck sways/leans
Fast68Chevy is offline   Reply With Quote
