Old 02-10-2005, 06:11 PM   #1
srosa707
Leaky question...
My steering ram is leeking on my 72. I have a pic but i dont know how to load it from my computer. I dont have my P/steering hooked up right now, could that be it? Driving the truck with no power steering? please help
srosa707 is offline   Reply With Quote
Old 02-10-2005, 06:22 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I CAN POST THE PIC - luv2xclr8@charter.net
DID YOU CAP OFF BOTH LINES, HOW IS IT DISCONNECTED
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-10-2005, 06:31 PM   #3
srosa707
i put a hose between the lines. I dont have a pulley for the power steering on my motor so i just took the pump off. NOw the ram is leaking.
Old 02-10-2005, 06:56 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
HMMM, NOT A EXPERT, JUST A GUESS, TOO MUCH PRESSURE
Old 02-10-2005, 09:23 PM   #5
srosa707
could those bolts be loose?? I have no idea...
Old 02-10-2005, 09:51 PM   #6
srosa707
could it be cause im drivin it with no power steering hooked up?
Old 02-10-2005, 10:04 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
IN ALL HONESTY, I WAS HOPING SOME OTHERS WOULD JUMP IN AND HELP W/ THIS
Old 02-10-2005, 10:41 PM   #8
srosa707
no kidding. Thats what im bankin on.
Old 02-11-2005, 07:57 AM   #9
JimKshortstep4x4
The upper seal is leaking and I suspect it is a pressure problem. When the steering box is hooked up to the PS pump and you turn the wheel, fluid is free to return to the pump on the return side. The way you have it hooked up now the return fluid is forced back into the pressure side and apparently it is dead heading. I believe that you have trapped the fluid and when you turn the wheel , pressure builds up. It may aleviate the problem if you disconnect the hose and turn the wheel side to side to bleed some of the fluid out.
I would suggest not driving the truck too long under these conditions as it could damage the steering box.
Jim
Old 02-11-2005, 08:06 AM   #10
Blazer1970
Blazer1970's Avatar
Yup, it used the tank as a vent, and you have blocked it off. Even a little heat buildup in the steering gear would build pressure inside. The easiest way for pressure to escape out of the box now is through the seals.
Blazer1970 is offline   Reply With Quote
Old 02-15-2005, 12:17 AM   #11
srosa707
thanks guys... ill do it tomorrow.
