Old 02-10-2005, 10:19 PM   #1
1968GMC
love my truck
1968GMC's Avatar
power steering box leaking, is it hard to fix?
So my box is leaking at the shaft. Is this an easy job for the novice or should I let a pro fix it?
1968GMC is offline   Reply With Quote
Old 02-10-2005, 11:18 PM   #2
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
yes somebody please answer. Mines doing the same thing and looking up in there looks like it might be a pain. Priced a new one online through napa $163.
WRMZ71 is offline   Reply With Quote
Old 02-11-2005, 12:02 AM   #3
jhow66
jhow66's Avatar
At the top shaft?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 02-11-2005, 04:18 AM   #4
GlennBrittain
I changed one out by myself a couple of weeks ago. I went the NAPA exchange route.
It is not that difficult to change one but I would recomend that you get someone to help. The box is a little heavy and ackward when starting the 1st bolt. I used a floor jack to lift it into position, but another set of hands would have made the job much easier.
GlennBrittain is offline   Reply With Quote
Old 02-11-2005, 10:37 AM   #5
Johnny05
Johnny05's Avatar
I've found over time that if it's leaking on one end and you repair it the other end will start to leak shortly there after and considering the time invested to repair it the best thing to do is just replace it with a rebuilt unit.
Johnny05 is offline   Reply With Quote
Old 02-11-2005, 11:15 AM   #6
jhow66
jhow66's Avatar
Fixed my top seal in the 90's--still dry both ends.
Old 02-11-2005, 02:34 PM   #7
dregs454
Killin' Time
dregs454's Avatar
easy to do, hard to find the right seal, Bumper to Bumper couldn't get me the right one (this is the top seal I'm talkin about)
NEED CORVETTE
1972 GMC C20
350, SM465, HEI
Dynomax headers and 2.5" duals
dregs454 is offline   Reply With Quote
Old 02-11-2005, 03:19 PM   #8
jhow66
jhow66's Avatar
Autozone--Part #= Powercraft 7095--$6.95
Old 02-11-2005, 04:40 PM   #9
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I did the top one on mine and it was real easy. Just unbolt the steering column and you can work right in the wheel well. Mine has been dry since and that was probably 3 years ago?
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 02-14-2005, 04:45 AM   #10
jimfulco
Anybody got a link to some instructions?
jimfulco is offline   Reply With Quote
Old 02-14-2005, 06:24 PM   #11
83K5350
83K5350's Avatar
When I replaced my top seal in my box, it came with the instructions.
'83 K5 w/ 350/TH350/NP203
4" Rough Country Springs
35" SSRs
Dana 44/60, 4.10s and welded rear
Edelbrock Performer intake
Edelbrock 600cfm carb
K&N Airfilter
Headman Headers
'71 GMC 1/2 ton shortbed 4x4 restored to original.
83K5350 is offline   Reply With Quote
Old 02-14-2005, 06:41 PM   #12
pierce
pierce's Avatar
Lucas Oil makes a power steering stop leak that's guaranteed. I used it on a Pontiac that was leaking and noisy. It was thick as maple syrup but it did the trick. Got it at Auto Zone.
69 GMC 1 Ton Longhorn
37 Chevy Coupe
pierce is offline   Reply With Quote
