02-11-2005, 05:41 PM | #1 |
Truck addict
What year did they start 4x4's?
What year did chevy actually start making four wheel drives from the factory?
I know before that they had Napco 4x4's when did that start? late fifties?
1956 Chevy Napco 1972 Cheyenne Super 1970 K20 |
02-11-2005, 05:50 PM | #2 |
Truck addict
1956 Chevy Napco 1972 Cheyenne Super 1970 K20 Last edited by Jeremy_5; 02-11-2005 at 05:53 PM. Reason: link wasn't working |
02-11-2005, 08:34 PM | #3 |
user # 2756
1960?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
02-12-2005, 12:33 AM | #4 |
Well Chevrolet did make CMP (Canadian Military Pattern) vehicles for WWII, they were considered to be 3/4ton 4x4s, however if you're talking about civilian trucks JIMs70GMC is right according to the Napco website 1960 was the first year that GM supposedly offered a factory 4x4, however 1ton 4x4s were not produced by GM until 1977.
Here's a couple of links: www.napco4x4.org www.oldcmp.net www.imbris.net/~conrad/trucks.html Edit: Btw Napco is now a part of the Dana Corporation. Last edited by James670X; 02-12-2005 at 01:12 AM. |
02-13-2005, 12:03 AM | #5 |
GMC offered a line built 4x4 in 1956 using NAPCO conversions, Chevy did line built NAPCO's in 1957. If you find an early truck the line built brackets are riveted to the chassis, the aftermarket installs are all bolted.
Larry 72 Chevy SWB 4x4 71 Chevy SWB 4x4 My Work Truck "Don't confuse enthusiasm with capability" |
02-13-2005, 12:06 AM | #6 |
Truck addict
good info ljbear, I will keep my eye out for that while I am searching for a 50's 4x4.
