Old 02-11-2005, 05:44 PM   #1
Tom
driving is in my blood
Tom's Avatar
cab mount bushings
For a long time I thought the bed on my 79 was tweaked to one side after the rear wheel fell off and got jammed up in there. Anyways my cab always looked like it was leaning in the back drivers side, or else the bed was bent the other way. I finally got a nice new bed thats perfect on, and its still leaning. So I just got some polyurathane cab bushings. Any advice before I start? I've heard this isen't too difficult, but not from anyone who actually owns one of our trucks
Old 02-11-2005, 08:29 PM   #2
us111
bushing's
hello,,i have never changed bushing's but i have the cab off my 76,,i really can't see where they would be hard to change other than spray the bolt's down best you can,soak em overnight,make sure however you lift cab up the few inches you may need is solid and u should be good to go....hope that helps .
us111 is offline   Reply With Quote
Old 02-11-2005, 08:41 PM   #3
1FaastC10
1FaastC10's Avatar
with my gutted cab, and no cab mount bolts in it at all, it was a bear to get them all to line up right. i would imagine if you did it one side at a time, you wouldnt have any problems.
1FaastC10 is offline   Reply With Quote
Old 02-11-2005, 08:41 PM   #4
1FaastC10
1FaastC10's Avatar
you're in AZ, the bolts should be gravy to remove.
Old 02-14-2005, 01:17 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Tom,
Shouldn't be a problem for ya at all. Just do one side at a time.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 02-14-2005, 01:26 PM   #6
DCRANER
Have you considered the ride quality of poly vs. stock rubber or black graphite impregnated. The poly is good for A-arm bushings, etc. in my opinion, but poly may be a little harsh for a cab mount. Just a thought.
86 GMC SWB, DK. BLUE, ZZ430,TH400, 4.11'S, HEADMAN CERAMIC HEADERS, WELD BILLETS, BFG 275 / 60 / 15, 325 / 50 / 15 DRAG RADIALS, FIBERGLASS COWL HOOD, B&M SHIFTER. MSD, MARCH PULLEYS / ALT. / PWR. STEER PUMP, BECOOL RAD., BILLET GRILL & GRANT WHEEL.
DCRANER is offline   Reply With Quote
Old 02-14-2005, 01:40 PM   #7
Tom
Tom's Avatar
This truck rides hard as it is, I don't think I'll notice the difference Besides, Im worried more about life span, not ride comfort.
Old 02-14-2005, 01:58 PM   #8
DCRANER
O/K. Then could I suggest you coat the bushings with a Waterproof Marine grease. That stuff will stick to the poly and avoid squeaks.
Old 02-14-2005, 06:11 PM   #9
TIMSPEED
TIMSPEED's Avatar
Tom,
I recently put the Energy Suspension Cab Mount Kit on my truck. It took about half an hour. The hardest part, was the core support bolts, mostly because all the crud that had built up on the bolt heads.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
