Old 02-11-2005, 07:57 PM   #1
cantontruck
cantontruck
Gear selector indicator
I purchased a 1972 Chevy a few months back and the gear indicators do not match the gear that the truck is in. I can line up a couple on either end of the indicator by moving the lickage from the column to the transmisson. Any ideas on how to fix this problem?
cantontruck is offline   Reply With Quote
Old 02-11-2005, 08:01 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
ASIDE FROM THE "P" , "R" , AND THE "N" HERE IS WHATS LEFT
WELL IF IT'S A POWERGLIDE IT WILL JUST HAVE A "D" AND A "L"
TURBO 350/400 WILL HAVE A "D" AND THEN A "L2" AND A "L1"
700R4 WOULD BE A SWAPPED IN UNIT "D" , "3" , "2" , AND "1"
I THINK THIS IS ALL CORRECT, KINDA TIRED AT THE MOMENT
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-11-2005, 09:18 PM   #3
cantontruck
cantontruck
Letters
The letters on the indicator are: Park. R,N,D,L2,L1
Old 02-11-2005, 09:51 PM   #4
teamharvey
teamharvey's Avatar
Do you know what tranny you have ?
71 Custom 20 Deluxe..soon to be SWB 1/2 ton
1 incredible wife
2 great kids
teamharvey is offline   Reply With Quote
Old 02-11-2005, 09:59 PM   #5
cantontruck
cantontruck
Transmission
The transmission is a 350.
Old 02-11-2005, 10:05 PM   #6
71Shortbed
71Shortbed's Avatar
I had the same problem. I adjusted it according to the manual and it still didn't line up. I loosened the column clamps and turned the whole column just a bit, replaced the linkage bushing at the column and transmission, and replaced the upper column bushing so that the lever wasn't as loose. Lines up fine now.
71Shortbed is offline   Reply With Quote
Old 02-11-2005, 10:10 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
MIGHT BE THE BEST WAY TO FIX IT
Old 02-11-2005, 10:11 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The stock nontilt columns are junk. When everything wears inside, the shifter won't line up right, and it'll bind and/or be too loose...ect.
