help with year of 4x4 chassis
I have a 3/4 ton 4x4 chassis under a 71 GMC 4x2 body. I am not sure of the year of the chassis, it has disc brakes, hub size for rims are 4 3/4" (see pictures), and the front leafs are 3" wide. I posted this in the 4x4 board too but I don't know if you all check that board.
![]() Join Date: Feb 2001
The same guys that will answer you over on the 4x4 fourms will answer you here.
Actually they dont like us 4x4 guys over here on their 67-72 board hehe Thats why Josh made us our own little place on the web over on the 4x4 forums. ![]() Last edited by Mudder; 02-12-2005 at 01:30 PM. |
There is a number stamped on the left front frame rail, near the power steering pump. It is part of the VIN number but I think it should tell you.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
Look in the area on top frame rail on drivers side near /just back of the steering box. Post me the numbers and letters there.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
Rod, there are no numbers where you indicated on this chassis, but I looked on my 72 and they are right where you said. I think the PO put the 3" springs on because the front spring mounts and the shackles are bolted on. What is the first year for disc brakes?
Is it just me or does that rear axle hub look like a FURD hub??? All the 3/4 and 1 ton axle hubs I've seen on these trucks are smooth and round, this one has ridges cut into it. I could be wrong but it's just something I noticed.
user # 2756
![]() Join Date: Jun 2001
That second pic is of a 14 bolt rear. 71 is the first year for disc.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
