02-12-2005, 02:11 PM | #1 |
Got big-block?
ending '77 tow rig project...new 454/700R4 for sale in Texas...other parts
Well, I broke down and bought a Suburban to tow/haul my stuff around, so I'm ending my '77 C20 project build. I don't need this 454 or 700R4 anymore (have plenty--see sig), so I'm going to put it up for sale here. I will let you pay out the 454 over a couple of months if needed.
Here goes: Just rebuilt (by E.T. Performance in Garland, TX) Short block: '73 2-bolt 454 bored .030 over. Everything balanced. Rods resized. Crank turned. New factory cast pistons (8.5-1). Clevite bearings. Mellings HV oil pump. Cloyes Tru-Roller chain and gears. New oil pan. Degreed Comp Cams 262H-11 hydraulic cam 218/226 dur and lift of .505/.515...nothing radical...damn good street cam. Comp hydraulic lifters. Heads: '73 big oval port 781's rebuilt with new valves (stock size) Comp springs, retainers, locks, Comp steel Magnum roller rockers, Comp rocker studs and Comp 7/16" pushrods. Intake is a Performer Plus aluminum intake. New waterpump. Chrome timing cover. Accel Hei. Everything is new. Engine was broken in on dyno (379hp/460lbft), and I have about 100 miles on it getting the truck and transmission dialed in. It runs very strong and has just a slight "lope" to it at idle...enough to let the other guys know "it ain't stock" . Engine is currently in the truck, so you can hear it run if you like. The carb is available separately, as well as the ceramic coated headers. No accessories like alt, ac, or brackets included...just the engine. $1700 firm, or if needed $1000 down and the rest negotiated. Here's a pic before it was installed: See below for info on the 700R4 trans.
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 Last edited by superchevy; 02-12-2005 at 02:21 PM. |
02-12-2005, 02:17 PM | #2 |
Got big-block?
700R4 specs
The 700R4 I have for sale is a fresh, rebuilt unit, with high performance clutches and bands. It took me a while to get everything modified to put it behind the 454 in the '77, but using the Bowtie Overdrive pieces, and having a friend here local who's a trans expert, we got it in and shifting very well.
It has the Bowtie overdrives lock up wiring installed in it, as well as the BTO "carb" spring for the TV valve. This trans has about 100 miles on it. It shifts very firmly into second, and crisply into 3rd and 4th. $450 plus shipping .... ti's heavy. 2200 stall lock up convertor, flexplate, and BTO tv-made-easy kit for Edelbrock carb all available separately.
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
02-12-2005, 02:24 PM | #3 |
Watch out for your cornhole !
Casey, are you selling the 3/4 ton truck too?
02-12-2005, 02:27 PM | #4 |
Got big-block?
Kevin, yes, I was going to list it for sale.
PM me if you want to talk it over. Casey
02-12-2005, 02:29 PM | #5 |
I don't have much money right now, I just know you always have clean trucks. I'd imagine you want more than I could scrape up extra.
I'm much more interested in the overdrive. How much extra for the torque converter?
02-12-2005, 02:30 PM | #6 |
The Anti-Rice
would the 700R4 work good in a 72 chevelle or is setup more for a tow rig? did you upgrade the servos in it? Is it slip or fixed rear yoke?
I MUD IN RICE PATTIES! (Mud Frog) 1972 K5,454,SM465/NP205 ,18" Over Stock,41" GH Tires, D60/14BFF,on a custom twin framerail tube chassis. (RICE KILLA) 1972 Chevelle 325 LM7 w/TR224 cam/ 2002 T56 6 Speed,4 wheel power disc,12 bolt w/ eaton & 3.55 (DD) 99 Dodge CTD 4x4 Short Bed |
02-12-2005, 02:30 PM | #7 |
Got big-block?
$100 for the convertor.
Let me know.
02-12-2005, 02:32 PM | #8 |
Got big-block?
Actually, the 700 was built for a hot rod...has the Corvette servo in it...supposed to be good for 500lbft.
02-12-2005, 02:34 PM | #9 |
The Anti-Rice
what kind of HP?
02-12-2005, 03:08 PM | #10 |
Got Big Block?
PM sent!
"Experience is what you get when you didn't get what you wanted." |
02-13-2005, 10:50 AM | #11 |
Got big-block?
still for sale
02-13-2005, 07:00 PM | #12 |
The Anti-Rice
still have trans and everything?
02-13-2005, 11:05 PM | #13 |
trans
Superchevy ,
Is the trans still in the truck and can it be driven. I might be interested in the trans and converter. I am about to start driving my 77 Bonanza and the OD would be nice. You can call me at 979-218-2936 days or send me your number and I will call tomorrow.Frank |
02-14-2005, 11:31 AM | #14 |
Got big-block?
more engine pics
pic
02-14-2005, 11:32 AM | #15 |
Got big-block?
pic
02-14-2005, 01:09 PM | #16 |
I may be interested and I'm in austin. Thinking about a crate engine, would this be too much engine for a daily driver?
02-15-2005, 10:44 AM | #17 |
Got big-block?
Trans is sold.
Thanks RingMaster.
02-15-2005, 05:04 PM | #18 |
computer illiterate
how much for he headers? brand/partnumber?
72 2wd blazer 72 swb 4x4 |
02-15-2005, 11:09 PM | #19 |
Got big-block?
I bought the headers used, but they are in great shape.
I can't find a brand or part number on them anywhere. They are full length, ceramic coated, with thick flanges. $125 + shipping.
02-15-2005, 11:15 PM | #20 |
Got Big Block?
Can you measure the width of the primaries and collectors?
Thanks!
02-16-2005, 08:54 AM | #21 | |
Is the tranny still for sale? Will it go behind the 350 in my '71? I would want the stall and the tv kit also.
2002 Silverado 2500HD LB7 CCSB LT EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's 2004 Tahoe LT 2006 Silverado Z71 LS 1971 Chevy C10 |
02-16-2005, 09:31 AM | #22 |
Got big-block?
Tranny/converter are sold to Ring Master.
PURS, I'll get the measurements on the headers for you. SC
02-16-2005, 02:30 PM | #23 |
computer illiterate
do you have a pic of how far they hang below the frame? i am interested in them
