Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 02-12-2005, 02:29 PM   #1
superchevy
Got big-block?
superchevy's Avatar
ending '77 C-20 project...new 454/700R4 for sale...more parts
Well, I broke down and bought a Suburban to tow/haul my stuff around, so I'm ending my '77 C20 project build. I don't need this 454 or 700R4 anymore (have plenty--see sig), so I'm going to put it up for sale here. I will let you pay out the 454 over a couple of months if needed.
Here goes:
Just rebuilt (by E.T. Performance in Garland, TX)
Short block:
'73 2-bolt 454 bored .030 over. Everything balanced. Rods resized. Crank turned. New factory cast pistons (8.5-1). Clevite bearings. Mellings HV oil pump. Cloyes Tru-Roller chain and gears. New oil pan.
Degreed Comp Cams 262H-11 hydraulic cam 218/226 dur and lift of .505/.515...nothing radical...damn good street cam. Comp hydraulic lifters.
Heads:
'73 big oval port 781's rebuilt with new valves (stock size) Comp springs, retainers, locks, Comp steel Magnum roller rockers, Comp rocker studs and Comp 7/16" pushrods.
Intake is a Performer Plus aluminum intake.
New waterpump. Chrome timing cover. Accel Hei. Everything is new.
Engine was broken in on dyno (379hp/460lbft), and I have about 100 miles on it getting the truck and transmission dialed in.
It runs very strong and has just a slight "lope" to it at idle...enough to let the other guys know "it ain't stock" .
Engine is currently in the truck, so you can hear it run if you like.
The carb is available separately, as well as the ceramic coated headers.
No accessories like alt, ac, or brackets included...just the engine.
$1700 firm, or if needed $1000 down and the rest negotiated.
Here's a pic before it was installed:
See below for info on the 700R4 trans.
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 02-12-2005, 02:34 PM   #2
superchevy
Got big-block?
superchevy's Avatar
700R4 info
The 700R4 I have for sale is a fresh, rebuilt unit, with high performance clutches, bands, and Corvette servo. It took me a while to get everything modified to put it behind the 454 in the '77, but using the Bowtie Overdrive pieces, and having a friend here local who's a trans expert, we got it in and shifting very well.
It has the Bowtie overdrives lock up wiring installed in it, as well as the BTO "carb" spring for the TV valve.
This trans has about 100 miles on it.
It shifts very firmly into second, and crisply into 3rd and 4th.
$450 plus shipping .... ti's heavy.
2200 stall lock up convertor, flexplate, and BTO tv-made-easy kit for Edelbrock carb all available separately.
build thread
build thread
Old 02-14-2005, 10:56 PM   #3
nn2004
Do you happen to know what year the tranny is? Would it work on an 87 w/a 350?
1987 Chevrolet R10 Custom Deluxe
Stock 350, TH350, 3.42 Rear
nn2004 is offline   Reply With Quote
