Got big-block?
![]() Join Date: Jul 2000
ending project '77 c20 ...454/700r4 for sale
Well, I broke down and bought a Suburban to tow/haul my stuff around, so I'm ending my '77 C20 project build. I don't need this 454 or 700R4 anymore (have plenty--see sig), so I'm going to put it up for sale here. I will let you pay out the 454 over a couple of months if needed.
Here goes: Just rebuilt (by E.T. Performance in Garland, TX) Short block: '73 2-bolt 454 bored .030 over. Everything balanced. Rods resized. Crank turned. New factory cast pistons (8.5-1). Clevite bearings. Mellings HV oil pump. Cloyes Tru-Roller chain and gears. New oil pan. Degreed Comp Cams 262H-11 hydraulic cam 218/226 dur and lift of .505/.515...nothing radical...damn good street cam. Comp hydraulic lifters. Heads: '73 big oval port 781's rebuilt with new valves (stock size) Comp springs, retainers, locks, Comp steel Magnum roller rockers, Comp rocker studs and Comp 7/16" pushrods. Intake is a Performer Plus aluminum intake. New waterpump. Chrome timing cover. Accel Hei. Everything is new. Engine was broken in on dyno (379hp/460lbft), and I have about 100 miles on it getting the truck and transmission dialed in. It runs very strong and has just a slight "lope" to it at idle...enough to let the other guys know "it ain't stock" . Engine is currently in the truck, so you can hear it run if you like. The carb is available separately, as well as the ceramic coated headers. No accessories like alt, ac, or brackets included...just the engine. $1700 firm, or if needed $1000 down and the rest negotiated. Here's a pic before it was installed: See below for info on the 700R4 trans.
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
