Old 02-12-2005, 05:16 PM   #1
Springbear
<<< Later! Wife's Calling
Springbear's Avatar
Help with small block Chevy engine identification??
So I am back from winter work and start working on my truck... lo an behold the block is cracked!
I found this block with a date code * 8 2 2 *
I believe this means 8th month, 2 day & 1972?
The other code is * V0204TDJ *
I believe this means ~
V = Flint Engine Plant
02 = February
04 = Day of Month
T = Truck
What does DJ mean?
Thanks for the help! Martin
Springbear is offline   Reply With Quote
Old 02-12-2005, 05:34 PM   #2
jef5150
Inline 69
jef5150's Avatar
i believe its =TDJ = 1972 350 conv.cab, a/t 175hp 4bbl C-10 & 20. got the info here under Small Block Engine Suffix Code Menu http://www.nastyz28.com/spmenu.html jeff
jef5150 is offline   Reply With Quote
Old 02-12-2005, 05:53 PM   #3
Springbear
Springbear's Avatar
I still am a bit confused... Does that mean GM did keep track of what blocks went to 2 wheel drive or 4 wheel drive? (I have been told they did not keep track...)
If I am to read http://www.nastyz28.com/spmenu.html correctly a suffix of TDR ~ 1972 TDR 350 conv. cab, a/t 175 4 K-10 & 20 would be the proper original engine for a 4 wheel drive K-20.
Comments?
Martin
Old 02-12-2005, 08:58 PM   #4
TRUCKGUY
TRUCKGUY's Avatar
you can also try www.mortec.com its a good place to find out anything chevy almost.
Dan.
55 F100 panel truck project
64 350/th400/10bolt short fleet
66 F100 302/C6/9" short fleet
67 IH 4x2 304/t984speed D44 373 locker lwb box
67 IH 4x4 304/t98 4speed/d44/d60 4.10'slwb box
67 IH Travelall 4x4 304/t98 4speed/12bolt/10bolt
81 2wd short fleet current build!
83 350/700r4 short fleet
88 k5 12" lift 3/4 ton swap mud toy
96 Dodge 3500 CUMMINS/5speed/4x2
97 Pontiac Trans Am WS6/LT1 383/6speed/T-tops
TRUCKGUY is offline   Reply With Quote
Old 02-14-2005, 01:31 AM   #5
Springbear
Springbear's Avatar
Thank you Dan... That web page is most helpful. Now I am wondering how important it is to have a block from a 4 WD going back into a "Restore Original" project. ?
Martin
Old 02-14-2005, 11:56 AM   #6
TsgtE662
2A674 Tank Rat
TsgtE662's Avatar
Per a GM Mechanical manual I have it shows for 1972:
TDJ as 350 = 4bbl, 175 hp @ 4000 / 290 ft lbs @ 2400, 8.5:1
4.000" Bore x 3.480" Stroke
w/ Auto
TFD,TFJ, TDJ, TDR, TRL, TLX, TFB, TDY, TRG are also shown with the Auto.
w/Manual = TBL, TFH, TDD, TDG, TRK, TRH, TLD, TLW, TFA, TDW,and TRD
w/ Manual w/LPG = TDH
w/ Auto w/LPG = TDK
'92 GMC Sierra, Sportside, 2wd, 350, Black
'92 Chevy Silverado Extended Cab 4 x 4, Blue
USAFR = 2A674 = Aircraft Fuel Systems Maintenance
i.e. Tank Rat
TsgtE662 is offline   Reply With Quote
Old 02-14-2005, 01:25 PM   #7
Springbear
Springbear's Avatar
w/ Auto
w/ Auto w/LPG = TDK
Thank you for the Information..... Zactly what I was hoping to get!
Martin
