Old 02-12-2005, 08:23 PM   #1
orangeuavol
GO VOLS!
orangeuavol's Avatar
painted my column
Painted my column today. I couldn't find saddle paint, but was able to have to paint matched to the steering wheel. I also finished converting a truck door to a blazer door, finished patching both inner fenders and the passenger side fender patched.
http://1972blazer.shutterfly.com/<= blazer build pics
It's called golf because all the other four letter words were taken.
It's easier to ask for forgiveness than for permission.
orangeuavol is offline   Reply With Quote
Old 02-12-2005, 08:25 PM   #2
orangeuavol
GO VOLS!
few more pics
more pics
Old 02-12-2005, 08:43 PM   #3
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Looks Great! Keep up the great progress!
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 02-12-2005, 09:27 PM   #4
TRUCKGUY
TRUCKGUY's Avatar
did you sand it first? what brand of paint you use? does it matter?
Dan.
55 F100 panel truck project
64 350/th400/10bolt short fleet
66 F100 302/C6/9" short fleet
67 IH 4x2 304/t984speed D44 373 locker lwb box
67 IH 4x4 304/t98 4speed/d44/d60 4.10'slwb box
67 IH Travelall 4x4 304/t98 4speed/12bolt/10bolt
81 2wd short fleet current build!
83 350/700r4 short fleet
88 k5 12" lift 3/4 ton swap mud toy
96 Dodge 3500 CUMMINS/5speed/4x2
97 Pontiac Trans Am WS6/LT1 383/6speed/T-tops
TRUCKGUY is offline   Reply With Quote
Old 02-12-2005, 10:26 PM   #5
c-1072
door
just a ? was that a new truck door and if so why not buy a blazer door ? just wondering .Also how was the conversion prosses any dos or donts to share .
c-1072 is offline   Reply With Quote
Old 02-12-2005, 10:43 PM   #6
Gyva
Gyva's Avatar
I just converted a truck door to a blazer door too not 4 days ago,,,, all I used was a angle grinder. did you transfer over the rubber window slider with block off. the trucks didn't have those or the top plastic piece that you have to drill 2 holes for and shave a side at an angle to get it to fit... rock on.
Gyva is offline   Reply With Quote
Old 02-13-2005, 12:01 AM   #7
orangeuavol
GO VOLS!
Sanded all the metal parts to bare metal, primed, and used Dupont acrylic enamel. The two plastic pieces I just roughed up with some 320 grit, primed, and sprayed with the acrylic enamel. The shifter piece is 'pot' metal so I used rattle can filler primer and spot-n-glaze putty to smooth it up.
Old 02-13-2005, 12:05 AM   #8
orangeuavol
GO VOLS!
That was a door off of the parts truck I bought this summer. The primer was a just a first coat to use as a guide to check if my patches were high or low. The hinges on my blazer door were ripping out. It was just easier to make a door since I had one to use. The conversion was pretty simple since I had a "go by". All I used was an angle die grinder with a metal cut off wheel.
Old 02-13-2005, 12:06 AM   #9
orangeuavol
GO VOLS!
yep.
Old 02-13-2005, 04:41 AM   #10
Trifelynn
Trifelynn's Avatar
a "?" as well, on my end....
What was your "go by"? the blazer door?
Always looking for a 2wd blazer
Trifelynn is offline   Reply With Quote
Old 02-13-2005, 10:43 AM   #11
orangeuavol
GO VOLS!
yep. transfered the measurement using measurment calipers.
Old 02-13-2005, 11:05 AM   #12
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
LOOKS GREAT UAVOL
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-14-2005, 07:35 PM   #13
orangeuavol
GO VOLS!
few more pics
here's a few more pics
Old 02-14-2005, 09:45 PM   #14
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks Damn Good...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-14-2005, 09:51 PM   #15
wally402
Some day I to will be at that point. looks good
1972 Blazer
wally402 is offline   Reply With Quote
