Old 02-12-2005, 11:11 PM   #1
Rdrdave
Broke and still trying
Rdrdave's Avatar
396 with 3 speed
I have a chance to get a 396 but I still have my 3 speed columnn (std) in my truck. I plan on changing it to a m22 or a richmond 5 but was wondering was there ever this option before that I will be able to even attempt it? I was wondering on the "z" bar and headers mainly.
I don't use my truck often but I do still will need it and don't want it sitting for too long. I am looking if anyone can get me some pics of their setup and suggest any type of headers I could use. I'm not into the resto so aftermarket parts will be great. I already have an idea for mounts(someone posted a set on here not too long ago) but have doubts on that 3 speed working until I blow it up.
Any suggestions would be greatly appreciated.
Rdrdave is offline   Reply With Quote
Old 02-13-2005, 10:43 AM   #2
LONGHAIR
Headers to fit around a column shifter.........I would doubt that. It's just to odd of a combination. If you tried to use some for an automatic to clear the shift linkage (I'm still not sure it would) then you would probably run into the clutch linkage down lower. If you used some for a stick truck, the shift linkage will probably be in the way.
You might get by with some "shorty headers" and having pipes bent at a muffler shop....or use iron manifolds.
That 3speed won't last long though.......either way
LONGHAIR is offline   Reply With Quote
Old 02-13-2005, 03:00 PM   #3
3 on the tree
The base tranny for the old ss 396 Chevelles was a 3 speed, so I guess it depends on which tranny you have.
3 on the tree is offline   Reply With Quote
Old 02-13-2005, 03:08 PM   #4
chevymad
The ss396 velles used a heavy duty version of the 3spd. Has double bearings on everything inside. Also chevelles used a tail tranny mount not the bellhousing mounts like these trucks. SS396s were floorshift as well. I had a 68 SS396 3spd console shift, all factory. Took apart the 3spd once, it only had a book showing the normal saginaw tranny, followed pretty close other then the double rows of bearings inside.
chevymad is offline   Reply With Quote
Old 02-13-2005, 03:30 PM   #5
Rdrdave
Rdrdave's Avatar
I don't mind switching to a floor shifter but once I spend on BB then a shifter will have to wait. I know the BB will explode the 3 speed but a tremec TKO is a bit pricey and I have another debate with Tremec TKO v. Richmond 5! OH the agony of choices! Thanks for the insite. I guess I'll keep looking!
Old 02-13-2005, 03:30 PM   #6
Rod
I came across a 396 3 speed on tree 3/4 ton 2wd once for sale...they were available that way.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 02-13-2005, 03:55 PM   #7
71Longbed
Not Mine But A beauty
71Longbed's Avatar
is the TKO the one In the 90's mustangs cuz i heard that the mustang 5 speeds are POS when it comes to powerful engines
68 Chevy Shortbed 454/400
2000 Chevrolet Camaro SS 6spd
2011 Silverado 5.3 6spd auto
71Longbed is offline   Reply With Quote
Old 02-16-2005, 09:38 PM   #8
Rdrdave
Rdrdave's Avatar
the t5 and 3550 are the POS trannies. Apparently the TKO I/II and TKO 500/600 are improved with larger gears. That's the read on them. I don't have one in my truck or know of anyone.
