Old 02-13-2005, 02:32 AM   #1
gregbr
Senoir Member
gregbr's Avatar
??Late model speedo sender unit question??
Anybody know if the electric speedo sender unit from the trans of a late model s-10 or fullsize will fit other transmissions.....say a T350? I would like to modify my dash using later model electric gauges from s-10, if the speedo sender can be made to work somehow. Any ideas..........Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 02-13-2005, 04:34 AM   #2
68LSS1
68LSS1's Avatar
You can get a box to convert a mechanical signal (cable) to electric. Go to Cable-X. Last time I checked they were about $300. You couldn't just do the sending unit as there is a ring internal to the tranny. You could do it but it would take a tail shaft/case change.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 02-13-2005, 05:03 AM   #3
gregbr
Senoir Member
gregbr's Avatar
WOW, is there not a cheaper way??
