Old 02-13-2005, 09:37 AM   #1
TwinTurbo
TwinTurbo's Avatar
Where's the horn relay on an 83??
Where's the horn relay? and also does anyone have a correct fusebox layout? The one I have is nowhere near accurate
TwinTurbo is offline   Reply With Quote
Old 02-13-2005, 11:07 AM   #2
cochino12
It followed me home?
cochino12's Avatar
The horn relay is a little white box between the dash speaker and the fuse box. Hope that makes sense? If you need a pic I can run out later and grab one for you.
Adam
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 02-13-2005, 11:52 AM   #3
TwinTurbo
TwinTurbo's Avatar
wow..is it way up there?? Time to do some digging then.
Old 02-13-2005, 12:25 PM   #4
TwinTurbo
TwinTurbo's Avatar
A pic would be handy, lotsa stuff up there behind the dash and I can't find the relay...
Old 02-14-2005, 03:50 AM   #5
TwinTurbo
TwinTurbo's Avatar
bump
Old 02-14-2005, 10:24 AM   #6
cochino12
cochino12's Avatar
Sorry man I guess it's right above the fuse box.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 02-14-2005, 11:01 AM   #7
TwinTurbo
TwinTurbo's Avatar
it's working again, discovered a water leak, that must be the problem.. now i'll have to pull the entire dash out..it's leaking behind the fusebox or a little above it.
Old 02-14-2005, 05:53 PM   #8
GMC1tondually4dr
Check the windshield seal and the door seal, that is the only place that there is a hole in the cab shell that would let water in.
Just my .02
CCDually
GMC1tondually4dr is offline   Reply With Quote
Old 02-14-2005, 06:04 PM   #9
TwinTurbo
TwinTurbo's Avatar
it's the caulking strip in the wiper area, i have a leak on both sides, the windshield and all weatherstripping is good, all that is new. It's running down the sides of the kick panels and soaks the carpet in the lowest spot There's some minor rust there also, damnit I had it all sprayed and now there's rust... I didn't have a leak when I rebuilt the damned thing 2 years ago. The insulation stuff is all wet, that's what caused the rust...had to rip it out, I removed it partly already. The moisture made the back brittle...that stuff is an excellent sponge
