Old 02-13-2005, 10:53 AM   #1
chevyboy55
chevyboy55's Avatar
Gas gauge help
Put the blazer tank in & hooked up the sending unit from the blazer tank to the wire to the gas gauge from the in cab tank. Now when the key is off it reads as having gas, when the key is turned on it goes to empty. It worked fine on the in cab tank. Ground is hooked up. With only 1 wire & a ground what could go wrong.
Thanks in advance, Mike
chevyboy55 is offline   Reply With Quote
