![]() Join Date: Apr 2002
I know this has been beat to death,BUtttttt,, I must have missed something. I have a 402 big block, a set of original 72 big block towers.Went to the part store to get a set of motor mounts for the 402. Bingo,not even close,back and was told that was all the puter showed!! Two other stores to make sure,same mount at all three.! Any ideas ,again i may just need a brain reset!
72 chevy C-10 swb fleetside,402 BB.700r4,buckets,console.etc. 72 Blazer CST 350,AT, new project 1971 Chevy Nova ,355 SB blow through turbo in works. |
Got Light Emitting Diode?
isnt the 72 ones like the 73 up ones? and the 71s are the wierd ones?
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
i think 72 was 1 year ony
computer illiterate
ive got a set of nos 67-71 frame mounts ill trade yah for those 72's?
72 2wd blazer 72 swb 4x4 |
![]() ![]() Join Date: Dec 1999
The tower for 72 is unique to itself. But the mount that bolts to it is the same as the mount for 73 and up.
Since it was a one year only deal the parts stores are morons about it. Just tell them you need the mount for 73.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
Thanks Meathead,but i have a 72 i am putting the 402 in...I'll take a look at the 73 mounts and see.Shouldnt be this hard,hahah!
Motor Mounts
Make sure you tell them a 73 454 because the small block mounts bolt in using different locations than the BB mounts. The BB use the top 2 and the lower is in the corner. The small block use the top 2 and the lower is in the center. the 72 BB frame stands only have lower hole for the corner not the center if I recall.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
thanks,,i'll give a 73 mount a try i have to the others back anyway!
Corection
Sinister - Hope you get this before you go. The BB use the center hole on the bottom and not the corner. My bad.
"Trucks with Class"
![]() Join Date: Jul 2000
Any of the 73 + clamshell MM should work. They are mount inserts that go inside your 72 clamshell. You drill out the rivets and use bolts to put it back together. Energy Suspension has an excellent eurthane replacements...look at their matching trans mount, too.
