My wife smells gas...
![]() Is it fairly typical to smell so much gas, or is there something I need to look at?
Hook'em |
Its a Truck Thing......
Check the fuel sending unit for leaks, then check all the rubber lines,also the fuel caps tend to leak when turning hard rights.......carb float could be stuck too....
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
The LuvShack Garage
ASSUMING THIS IS A IN THE CAB GAS TANK
![]() COULD BE THE O-RING/GASKET AROUND THE SENDING UNIT ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
It is an in the cab tank, but most of the smell comes from under the hood. I will check all of the above. Thanks. Any other thoughts are welcome.
Hook'em |
check the carb linkage that goes into the carb, some will leak out there when worn
My rubber fuel line failed (under the cab) and slowly lost almost a full tank of hightest when it was parked for a few weeks. I replaced the line and installed new clamps also, the old line was in really bad shape.
Fuel pump could be pumping gas out the vent holes (bursted dia. in pump).
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
GO VOLS!
what? No fart jokes
http://1972blazer.shutterfly.com/<= blazer build pics It's called golf because all the other four letter words were taken. It's easier to ask for forgiveness than for permission. |
#9 | |
Cantankerous Geezer
Fred There is no such thing as too much cam...just not enough engine. ![]() |
