Old 02-13-2005, 11:38 PM   #1
skokie
skokie's Avatar
Harmonic balancer swap tonight
Im doing the balancer swap tonight. I want to make sure that I am not missign anything. I have a puller and installer.
Removal:
Mark where the balancer is.
Using puller to remove the balancer and key
Install:
Put a little grease on the seal in the timing chain cover /crank seal
Use the installed to press the balancer on.
Install the key into the crank (how far do I go in with that key? Will it just stop?)
With flexplate blocked torque the balancer bolt to 65 lbs.
Ok did I miss anything? There will be pics on this one
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 02-13-2005, 11:56 PM   #2
neonlarry
neonlarry's Avatar
Iv'e always installed mine with the key already in the crank it helps keep the balancer lined up in the proper orientation.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 02-14-2005, 12:12 AM   #3
rustyold72
rustyold72's Avatar
71 Chevy C10 "The Rust Bucket"
72 Chevy C10 apart in the garage
02 WS6 T/A Fast Black and bad@$$
93 Nissan Pathfinder "Emily" Totaled RIP girl
05 Jeep Grand Cherokee-HEMI powered
87 Iroc Z28 305 TPI auto (crying out for an LS1 swap)
rustyold72 is offline   Reply With Quote
Old 02-14-2005, 12:24 AM   #4
skokie
skokie's Avatar
Ok. Should I replace the key since I am in there? Or leave the original one in place?
68 build thread
Old 02-14-2005, 12:28 AM   #5
rustyold72
rustyold72's Avatar
I always replaced them,(my personal preferance) but if your key is good, then there's no reason not to reuse it
Old 02-14-2005, 12:36 AM   #6
RON WOODGEARD
Resident Young Old Dude !
All the key does is keep the balancer and crank aligned. It should be stuck to the crank. Leave it there and put the balancer back on. Usually the crank groove (Keyway) is pretty tight, and you have to tap the key into the "Keyway" with a small hammer. or a tap and hammer.
I use a 6" long piece of 2X4 laying across the front of the balancer and tap the 2X4 with a hammer to seat it in place before installing and tightening the bolt. You may HAVE to do this, The bolt may not be long enough for the threads to start grabbing without the Balancer seating in some.
DO NOT HIT THE BALANCER WITH THE HAMMER..and don't hit it on the outside edges..
RON WOODGEARD is offline   Reply With Quote
Old 02-14-2005, 12:49 AM   #7
skokie
skokie's Avatar
Ok crank pulleys are off. Fan is about to be off. I will post pics after I get everything apart.
68 build thread
Old 02-14-2005, 01:06 AM   #8
skokie
skokie's Avatar
Ok the fan is off. Its go time
68 build thread
Old 02-14-2005, 01:33 AM   #9
skokie
skokie's Avatar
Ok the old one is off. The key looks like its ok so I am going to leave it alone. Here is a pic of the old balancer. The rubber on the back ofthe old one is very dry and is peeling off in some places. The rubber on the timign chain seal looks good on the inside. Time for the new balancer to go on.
68 build thread
Old 02-14-2005, 01:56 AM   #10
skokie
skokie's Avatar
Its halfway on. Im taking a break here for a sec. Man this is like workout
68 build thread
Old 02-14-2005, 02:03 AM   #11
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
why are you replacing it?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 02-14-2005, 02:42 AM   #12
Russell
Professional Grade
Russell's Avatar
What are you using to re-install it?
I gotta put a balancer on, but I cannot find a tool for it anywhere...
I've heard about people making their own balancers, but I've never seen any pictures, and descriptions don't always work so well, lol
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 02-14-2005, 02:51 AM   #13
67ChevyC10Stepside
making your own balancer? dont think that would work so well...lol....for the tool look in summit.
Old 02-14-2005, 02:58 AM   #14
4x4Poet
A potential source for an harmonic damper installer/puller.
Skokie, maybe you can take a pic of yours in action.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 02-14-2005, 03:41 AM   #15
skokie
skokie's Avatar
That one is real close to the one I have. Sorry I am already done. Heres the results. I cant get it flush with the timing tab. Its close though like maybe 1/4 of an inch. I can see a gap on the crank snout and the balancer onthe back. What I realized is that my old balancer wasnt even that far in. So the vibration I was feeling has gotten somewhat better. Any ideas on how I can get this balancer in all the way?
I will post the pics tomorrow.
68 build thread
Old 02-14-2005, 12:03 PM   #16
neonlarry
neonlarry's Avatar
You can hone out the inside a little with a brake cylinder hone to get it to fit.
Old 02-14-2005, 01:08 PM   #17
skokie
skokie's Avatar
Well all in all it wasnt to bad. I will post the pics tonight when I get home. I took another look at the original balancer and it was pretty shredded on the back side. Also it kinda looked warped and after thinking on it a bit I may know why. Since I have the new blanacer on and the timing tab is maybe 1/4 inch from being flush from the balancer. On the original the timing tab was maybe halfway across the timing tab. So I dont think it was pressed on fully to begin with. But hey I could be wrong.
Guys thanks for all the help I greatly appreciate it. I am going to finish the job tonight and hope for the best. If I cant get it on the rest of the way then the machine shop guy I spoke to this morning said that he would take care of it and cheap to. Maybe I should have asked him to install it in the first place HAHHA
68 build thread
