![]() Join Date: Sep 2004
Front drop? Spindles? Springs? Both?
I hauled home the 71 Super Cheyenne yesterday. Now the work starts.
I was thinking about 2 1/2 drop spindles and 1" drop springs. But what happens if I just use 4" drop springs? Will also be dropping the rear. Does anyone use car/salvage yard springs that will work in our trucks? Thanks aitch |
Happy to be here
![]() Join Date: Mar 2000
I do not recommend using 4" dropped springs. You will not be pleased with the ride from that short of a spring unless your after a very firm suspension.
I suggest dropped spindles or A-arms and a 2" spring. You can get the same thing buy cutting a coil off your stock spring if they are in good shape.... ![]()
If you use a 4" spring alone, you'll have a ride that your kidneys will hate you for,
I'm going with the springs (2" drop) and the spindles(2 1/2" drop), I based it on riding in a friends truck, rode better dropped than it did stock
71 Chevy C10 "The Rust Bucket" 72 Chevy C10 apart in the garage 02 WS6 T/A Fast Black and bad@$$ 93 Nissan Pathfinder "Emily" Totaled RIP girl ![]() 05 Jeep Grand Cherokee-HEMI powered ![]() 87 Iroc Z28 305 TPI auto (crying out for an LS1 swap) |
I just ordered by drop spindles and springs from ECE. I looked at ALOT of different set ups and this seemed like the best.
#5 | |
For every person with a spark of genius, There are a hundred with ignition trouble. ![]() |
Can I go to 73+ spindles and rotors at this time? What all is needed?
Watch out for your cornhole !
![]() Join Date: Jun 2003
Yes, you can use the 73 and newer parts. You'll need to change your upper ball joints and outer tie rod ends.
The lower ball joints are the same. And, brake rotors and bearings are the same from 71-on until they went to the thinner rotors in the 80's. Reuse your calipers and caliper bolts on the newer spindles.
#8 | |
Rotors
