02-14-2005, 12:39 PM | #1 |
where to get oil line?
i had my oil pressure line out in my truck and i got new fittings for it and had it one night then it just dissappeared.....where can i buy a new one?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
02-15-2005, 09:03 AM | #2 |
Watch out for your cornhole !
Any local hydraulic hose shop will stock them.
Take the line in there so they can see what you're talking about. Last one I bought was a few months ago and I got brand new everything from the guage to the engine for about 10 dollars. That's all new brass line and fittings.
02-15-2005, 01:20 PM | #3 |
if i had the line i wouldn't need one....lol
02-15-2005, 07:08 PM | #4 |
Auto Meter Makes A 6 Foot Copper Line With Fittings For About $11. They Are Available At Summit Or Jegs Or Anyone Else That Sell Auto Meter Products. Pt. # 3224 John
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 02-15-2005 at 10:57 PM. |
02-15-2005, 09:25 PM | #5 |
I just bought some of this 1/8" copper line at "Pep Boys"
72 Chevy A/C P/B P/S Tilt 454 Engine 400 TCI Trans C30 Frame C10 Suspension Short Wheel Base (Dually) |
02-15-2005, 11:11 PM | #6 |
but will that work with out guage? i bought one of the nylon oil pressure setups and none of the fittings will fit the guage.
02-15-2005, 11:28 PM | #7 |
Merciless Butcher
67chevyc10stepside....I have a few hundred of the 1/8" breakaway ferrules if you need a couple. Those are what Chevy used when they made them......Let me know....But, they will only work on steel or copper line.
Your Bought And Sold....I Got Your Soul! |
02-15-2005, 11:38 PM | #8 |
what is that? i dont know anything about this stuff? i know how to bend and do double flares on brake lines.....that's it
02-16-2005, 01:00 AM | #9 |
Merciless Butcher
Those are the brass fittings used on the ends of the oil line. One goes into the gauge and the other end goes into the adapter on the block. If you're using nylon line, you need the two piece compression ferrule. I'll post a pic for you tomorrow...I don't feel like going to the garage right now.
02-16-2005, 10:36 PM | #10 |
Merciless Butcher
Breakaway Ferrule
Here's a pic of breakaway ferrules for ya 67chevy. They will only work on steel, aluminum or copper tubing. These are basically the same thing that GM used on the ends of oil pressure lines when your truck was made. They're easy to use. Just cut the tubing to length then slide the fitting on the tubing. While your threading the fitting into the back of the gauge or the adapter on the block, push the tubing tight against the gauge or adapter. As the fitting is tightened down with a wrench the fitting squashes a little and becomes permanently attached to the oil line. Once it's attached, it can be unscrewed from the gauge again and again and it won't leak. Other ferrules are two piece and have a nut and a small "barrell" shaped piece. Those are usually used on aftermarket gauges. The fittings in the pic will only work on factory gauges.
02-16-2005, 11:17 PM | #11 |
so how about sending me 2 of em in an envelope?
02-17-2005, 12:41 AM | #12 |
Merciless Butcher
Not a problem....Send me a PM with your address.....Greg
