Old 02-14-2005, 12:41 PM   #1
arkracing
Weekend Warrior
???Headers???
For you guys running small blocks on I6 motor mounts
will headers designed for these trucks 67-72 fit on the motor with I6 mounts without clearance problems???
and if so does anyone have a good used set they would be willing to sell???
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 02-14-2005, 04:12 PM   #2
arkracing
Weekend Warrior
ttt
-'66 C10 Suburban
Old 02-14-2005, 05:42 PM   #3
gmc67swb
gmc67swb's Avatar
I have hedman headers on mine. '67 gmc swb with 2wd and manual trans. The only issue I had was with the clutch linkage. A little finesse and it's worked trouble free for 17yrs. Same headers for that long too.
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 02-14-2005, 07:25 PM   #4
Inspector722
Fixing my 67, & loving it
Inspector722's Avatar
What does running a V8 on I6 mounts do to the engine asa far as placment goes?
Email address- inspector722@aol.com
Zip Code- 77611
Shipping- DHL & USPS
Working on: 67, large back glass, 307 V8, 200 4R, 3.73 rearend, Short Stepside Bed
Inspector722 is offline   Reply With Quote
Old 02-15-2005, 12:17 AM   #5
arkracing
Weekend Warrior
moves it back toward the firewall about an 1.5" or so?? (not sure on how much)
-'66 C10 Suburban
Old 02-15-2005, 12:25 AM   #6
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
mine is 400 sb in inline 6 position with headers.....works fine...if you run auto you need to modify the one little bar....i have a modded one i can get a pic of if needed....my truck used to be manual so i still have some of the manual stuff.....there are pics to show what it does to position as well....
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 02-15-2005, 01:29 AM   #7
454_72_4X4
454_72_4X4's Avatar
Alright, I'm not very familiar with all the positions. Let me get this straight, the I6 position is the farther back of the two? That seems backwards to me since the I6 is the longer of the two motors and that would seem to make the mounts farther forward?
According to your pics 67ChevyC10Stepside, I would consider that the small block V8 position. (Just how it seems to me, not saying you're wrong). I've never really looked at a I6 truck, but I do know my factory V8 mounts are in the same position as yours are in the pics. Mines 4x4 too. Does that make a difference? The forward holes are big block position too, correct?
Back to the original ?, I had Cyclone? headers on mine, (when it was small block powered), and didn't have any problems with the clutch linkage.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 02-15-2005, 01:41 AM   #8
67ChevyC10Stepside
4x4s are in inline 6 position i think........i6 is farther back to because of the extra two cylinders stickin out the front.....mine is I6 position....that's why there is so much room between my fan and rad.....
Old 02-15-2005, 02:00 AM   #9
454_72_4X4
454_72_4X4's Avatar
Hmm, I guess that makes sense...somewhat.LOL
If that's the case I've only seen one truck with a V8 in the V8 position! I think I'll just call them "forward" and "rear"!
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 02-15-2005, 02:10 AM   #10
dogman
My motor(350) is set in the I6 position also . I was running Flowtech headers and really didnt have any problems other than exhaust leaks . Things are a bit tight down there , but nothing anybody cant handle. I am going to sell them , if you might be interested PM me . I can get some pic's if you would like ...Thanks
dogman is offline   Reply With Quote
Old 02-15-2005, 09:39 AM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've run Hooker Comps on small block in 6 cylinder position before without interference issues at all.
It was a standard transmission truck too, so I still had the z-bar and clutch linkage. It all worked fine.
Old 02-15-2005, 09:53 AM   #12
arkracing
Weekend Warrior
Thanks, PM sent
Hooker Comps are expensive though....I don't really want to spend alot of money as i'm going to be foreced to sell the truck anyway
-'66 C10 Suburban
Old 02-15-2005, 09:56 AM   #13
Tx Firefighter
Originally Posted by arkracing
Thanks, PM sent
The Comps are the cheap ones. I think they run about 150 nowdays.
Old 02-16-2005, 02:37 AM   #14
dogman
Thanks, PM sent
Sent one back your way ....Thanks
