Old 02-14-2005, 08:10 PM   #1
k5b
temp gauge question
On my factory temp gauge the 1st line reads 100, the 2nd line is blank, and the 3rd line reads 210. What temp would the 2nd line be?
85 K5 Blazer
k5b is offline   Reply With Quote
Old 02-14-2005, 08:11 PM   #2
CbHeEaVsYt
Pick up man
CbHeEaVsYt's Avatar
my geuss would be 155 if its right in the middle
cb
heres sum pics of my truck
82 silverado c10
heres my baby
1990 k1500
check out this 1957 chevrolet for sale
CbHeEaVsYt is offline   Reply With Quote
Old 02-14-2005, 09:40 PM   #3
k5b
Thats what I am thinking but my blazer hardly ever goes over the second line,so that means I am always running around 155? does that sound right?
85 K5 Blazer
Old 02-14-2005, 10:08 PM   #4
SanitysBane
180 would be my guess
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 02-14-2005, 11:45 PM   #5
CbHeEaVsYt
Pick up man
CbHeEaVsYt's Avatar
y 180 155 is right between 100 210
cb
82 silverado c10
heres my baby
1990 k1500
Old 02-14-2005, 11:59 PM   #6
SanitysBane
just a thought
'88 K5 Blazer
Old 02-15-2005, 11:37 PM   #7
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
The factory guages were never very accurate. Though it would seem 155 is correct, you must take into consideration where the sender is before condeming the factory set-up.
If in the head, it is possible that the water in that location is not yet up to thermostat temp (water moves to the rear of the block, up to the heads along the way, and then to the front of the heads and out the intake. Unless it is a newer engine. ) so then 155 would be close. If however your sender is in the intake, the guage temperature should indicate the same temp as the opening temp of the thermostat. Then 180 would be more likely. And therefore the guage is incorrect.
Just a thought.
NeCrOmAnCeR is offline   Reply With Quote
