Old 02-14-2005, 10:10 PM   #1
Kat
Question Info on a couple motors by the #'s?
I need some information on the stamp pad #'s on a couple motors.I have a castings #'s book,but have not been able to run down the stamped #'s on any of the stamped #'s websites.The 1st one has casting # of 3970010 = 69 and up 350, with stamped # VO223TDD.The 2nd has a casting # 3970024= a 307 '69-73, stamped # TO51700A. Thanks
Kat is offline   Reply With Quote
Old 02-14-2005, 10:54 PM   #2
bigjimzlll
bigjimzlll's Avatar
1972 TDD 350
1980 TDD 350 conv.cab m/t L LS9 155 4 C-20 & 2500
and this is as close as I can get to the 307
1968 DA 307 man trans, 3 spd - 200 2 A F X
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 02-15-2005, 12:12 AM   #3
TRUCKGUY
TRUCKGUY's Avatar
try............... www.mortec.com ...........great info there
Dan.
55 F100 panel truck project
64 350/th400/10bolt short fleet
66 F100 302/C6/9" short fleet
67 IH 4x2 304/t984speed D44 373 locker lwb box
67 IH 4x4 304/t98 4speed/d44/d60 4.10'slwb box
67 IH Travelall 4x4 304/t98 4speed/12bolt/10bolt
81 2wd short fleet current build!
83 350/700r4 short fleet
88 k5 12" lift 3/4 ton swap mud toy
96 Dodge 3500 CUMMINS/5speed/4x2
97 Pontiac Trans Am WS6/LT1 383/6speed/T-tops
TRUCKGUY is offline   Reply With Quote
Old 02-15-2005, 11:29 PM   #4
Kat
ttt
Old 02-16-2005, 01:06 AM   #5
bigjimzlll
bigjimzlll's Avatar
well I nailed down the first one...I believe if you look close at your numbers on the 307 closer..its probably a DA....
Anderson,CA
