Old 02-14-2005, 11:24 PM   #1
Sooner1970_K10
1970 K10, 350, 4spd!
Sooner1970_K10's Avatar
Removing a welded bumper/want to reuse!
Ok, quick question. Below is a picture of my (dealer installed bumper?) that I would like to remove and get powder coated. One slight problem. Its welded to the frame in about 10+ spots. Is there any way possible I will be able to get this off and reuse it or is that out of the question? I have no welding experience what-so-ever. Thanks again!
Sooner1970_K10 is offline   Reply With Quote
Old 02-14-2005, 11:38 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I used an angle grinder to remove mine. Still ended up strapping it to a tree and getting whiplash.
I was told the whole back of the truck came off the ground.
Old 02-14-2005, 11:43 PM   #3
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Yep, Andy's right. Get a good angle grinder and give it hell.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 02-14-2005, 11:53 PM   #4
krue
Designated A-hole!
krue's Avatar
Just remember it's only metal. You can always weld it back on.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 02-15-2005, 12:00 AM   #5
tnblazerk5
User #12137
tnblazerk5's Avatar
the last one i did i used a red wrench to get it off but i had to make new brakets to put it back on and i also had to use a strap and a tree too
tnblazerk5 is offline   Reply With Quote
Old 02-15-2005, 01:10 AM   #6
Rollie396
someday it will be done!
Rollie396's Avatar
yup angle grinder with a 1/8" disc to take the welds down to the parent metal.If you don't want whiplash ( )put on a zipcut and carefully grind into the joint(mostly on the bracket so you don't gouge the frame)until you see the crack between the two plates.If you want to save the brackets then you can either fill the grind marks with weld and grind,or radius the edges with the grinder to smooth things out a bit.Let us know how it goes!
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
