Old 02-15-2005, 01:59 AM   #1
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
i need a checklist
what all do i need to put a 67 front clip together? i think the guy with the 67 stuff is gonna come down on price some. i need to know EVERYTHING i need to put it together...i know all the big pieces like fenders hood grill grill trim bezels headlights hinges wiring harness....what else? what kind of bolts and stuff?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 02-15-2005, 04:21 AM   #2
ryanroo
ryanroo's Avatar
i know you will need the radiator support. bolts and such i do not know, i have only had trucks 1970 and newer but i can't think that there is much difference. if you are buying the front clip complete then i would think that you would get all of the related hardware with it. ask to see what the seller had to remove to get the clip off and see if you can get it with the sale. good luck
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 02-15-2005, 08:58 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Hinges are the same from 67-72.
You also need the lower splash pan that goes between the core support and the grille.
90 percent of the bolts in the front clip are 5/16. You can buy them by the box at any hardware store.
