02-15-2005, 05:20 AM | #1 |
removing fuel tank behind seat, going to fuelcell
whats the best way to remove the tank behind seat.
67-72 GMC long bed building drag truck so in goes fuel cell. any advice from the masters out there? |
02-15-2005, 08:03 AM | #2 |
user # 2756
make sure it's empty, damn thing is awkward as it is, fuel moving around does not help. I recommend removing the seat first.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
02-15-2005, 08:17 AM | #3 |
67 is sold
I agree. Remove the seat, Remove the tank cap and grommet, remove as much of the gas as you can (not required), unbolt the tank and sending unit and remove
Post some pics of this truck |
02-15-2005, 09:11 AM | #4 |
I have a brand new never installed 8gallon fuelcell 50.00 + shipping
Rest in Peace Ed. Thanks for all the good times. |
02-15-2005, 10:10 PM | #5 |
Is a 8 gallon tank the way to go or whats a good size fo a fuel cell.
plus I live in Calgary, Alberta. need to find good parts/high perf.shop and also I thought there was more to taking those tanks out! like cutting. Thanks for the advice guys |
02-15-2005, 10:18 PM | #6 | |
Seņor Member
02-15-2005, 10:32 PM | #7 |
Yah it's extremely easy, I thought the same thing
BTW cut the grommet, soooo much easier. And if I can do it myself, without scratch's, anybody can. Last edited by Georgie69; 02-15-2005 at 10:36 PM. |
02-15-2005, 10:33 PM | #8 |
68cst_ss490
If you arer using it for racing go with an 8 gallon. But if you want to use it for cruising go with a 16 or 20 gallon cell. Try Mopac down there we have one up here and they are resonably priced
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
02-15-2005, 10:43 PM | #9 |
I have a 20 gallon cell in my truck and it is just right! Iit is pretty big and takes up some space but I like the way it looks :-) its right in the front of my bed, and it holds just enough fuel for cruising around. On the track though I empty the tank completly and pour in 2-gallons of c-16 for better running and less weight.
Man I need another 67-72!!! |
