![]() Join Date: Aug 2003
Master cylinder??
Mine is leaking something bad and I need to get a new one. Where would be the best place to get one?
Also, There's a tube coming out of my Carb and running into the cylinder. I'm guessing it's a "vacuum assist" type of unit? Can someone tell me what kind I have and what options I might have in replacing or switching out or ??? Also, My starter is starting to go, anyone got a good source for these too? By the way, It's a '77 350, 4-barrel with a 350 tranny, if that helps. Thanks Any info will be greatly appreciated.
1968 SWB. GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators. Remember, no matter where you go, There you are. Gary |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Any local chain parts store will have the master cylinder. Usually under 20 bucks.
Thanks Tex. I'm still wondering if the kind of Master cylinder I have is all that common. I've only seen a few of the "Vacuum" type and wasn't sure if they're common.
Is there a number I should try to find on the cylinder or just tell them what year motor I have?
its all about the +6 inches
The engine wont matter. Power brakes verses manual brakes wont mater either. The parts guy will tell you it matters, but you can prove him wrong by tellin him to look at the part numbers for both aplications.
power brakes is a common option. |
Got my friends @ Autozone, asked for a master cylinder for a 77 1/2 ton Chevy pickup with power brakes (like TX said under $20)
71 Chevy C10 "The Rust Bucket" 72 Chevy C10 apart in the garage 02 WS6 T/A Fast Black and bad@$$ 93 Nissan Pathfinder "Emily" Totaled RIP girl ![]() 05 Jeep Grand Cherokee-HEMI powered ![]() 87 Iroc Z28 305 TPI auto (crying out for an LS1 swap) |
rusty, did you get a 77 master cylinder for a 67 - 72?
