Old 02-15-2005, 10:37 AM   #1
painteralg
painteralg's Avatar
temp sensor connector name
Does anyone know the proper name of the connector to use for a temp sensor that looks like a nail head? The previous owner cut it off and used the idiot lights instead of the gauge. I like to pick one up at NAPA to see if that fixes my temp gauge problem.
Thanks in advance
painteralg is offline   Reply With Quote
Old 02-15-2005, 11:20 AM   #2
da-burb
"Ochre Ogre"
da-burb's Avatar
It isn't original, but I have always used a female spade connector. It needs to be opened up a little to fit but it works.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 02-15-2005, 01:07 PM   #3
demi
demi's Avatar
That connection is called a slider.
demi is offline   Reply With Quote
Old 02-15-2005, 01:24 PM   #4
poff
I cool parts person at the dealer should be able to find you one. In the "shop" side of the counter they usually have drawers or bins with all of the different connecters. You may also find them in the Help section at the auto parts store but the quality of connecters varies quite a bit. Also try sending an email to Sallee Chevrolet, they have a really good parts department.
'70 K-20 San Diego, CA
poff is offline   Reply With Quote
Old 02-15-2005, 01:35 PM   #5
67chevemall
67chevemall's Avatar
Slide it in right to the top! Were gonna slide it in!slide it in!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 02-15-2005, 01:52 PM   #6
painteralg
painteralg's Avatar
Thanks, But the three guys at NAPA had never seen them before so they sold me the spade lug type (for idiot light) that type will not work with the temp gauge in the cluster.
Old 02-15-2005, 03:07 PM   #7
70 longbed
Try asking for a female GM 56 series connector. There is a connector housing that allows you to slide the connector on and give it some protection. Good luck trying to find the housing, but the connectors are pretty common.
Keith
70 CST longbed in progress. Hoping to get it back on the road soon.
70 longbed is offline   Reply With Quote
Old 02-15-2005, 04:45 PM   #8
1-PU70
1-PU70's Avatar
I know I have seen the cinector some where but I cant remember. This is what your looking for with the wire and heat covering
http://www.ecklers.com/product.asp?p...D42RWQ7BW2BPB8
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 02-15-2005, 05:00 PM   #9
70 longbed
That's a nice little kit. It takes the connector I was talking about and has the connector body and what looks like the original style heat covering. It is for corvette, but common to all chevy.
Keith
Old 02-15-2005, 06:28 PM   #10
sirhollow
Try this site: http://www.sherco-auto.com/cg.htm They seem to have both the terminal and the insulator. The part # is CG7 for the GM 56 series female connector and part # CG45 for the insulator.
sirhollow is offline   Reply With Quote
Old 10-02-2014, 04:51 PM   #11
jimbosprint
jimbosprint's Avatar
Re: temp sensor connector name
Anyone know where to get this temp sensor connector? The slide-on connector for a nail-head style sensor.
I've been to a couple local auto parts stores with no success.
jimbosprint is offline   Reply With Quote
Old 10-02-2014, 05:34 PM   #12
Grumpy old man
Grumpy old man's Avatar
AC Delco part # G1852 new temp sensor comes with plastic sleeve to attach wire sold by rockauto.com $14.35 +shipping
Alternative part #'s
AC DELCO 1234869
AC DELCO 1513321.....................
Grumpy old man is offline   Reply With Quote
Old 10-02-2014, 05:41 PM   #13
jimbosprint
Ok, so my new temp sending unit also came with the plastic sleeve. Is the terminal under the sleeve just a female 56 series connector?
Old 10-02-2014, 07:11 PM   #14
FirstOwner69
FirstOwner69's Avatar
Try this link. Wire should be green though.
http://www.repairconnector.com/produ...Connector.html
I think this is the actual connector.
http://www.repairconnector.com/brass...ector-10-pack/
FirstOwner69 is offline   Reply With Quote
Old 10-06-2014, 05:35 PM   #15
jimbosprint
For anyone that finds this thread later, the correct connector is a female 56 style terminal (Napa part# NW 725147). The temp sensor comes with the plastic sleeve.
