Old 05-30-2002, 02:58 AM   #1
Mitzki5
"TRUCKLESS"
Mitzki5's Avatar
Would a ...
Would a rearend from a 70 3/4 ton custom camper swap directly out with my rearend on my 69 GMC 1/2 ton? Both are leaf rears. Thanks a lot!
Mitzki5
No longer have an old truck! But always looking for another one!
Mitzki5 is offline   Reply With Quote
Old 05-30-2002, 06:18 AM   #2
Big69C20 Toy
Livin' it up.
Big69C20 Toy's Avatar
I'm thinking if the axle tubes are the same size, yeah shouldnt be a problem. You might have to find specialty sized U joints though, because the bigger rear might want a larger cap than the 1/2 tons driveshaft. Shouldnt be hard to find those though, i heard of several companies/people that used em. Try to do some good measuring though, make sure things wont catch or rub or anything, hate to have that happen
-Greg;
Sold the 69 C20. It's off to a better home with more love!
Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires.
Big69C20 Toy is offline   Reply With Quote
Old 05-30-2002, 12:15 PM   #3
Mike C
Mike C's Avatar
Maybe. Some trucks have 40" spring centers (Longhorns, 4x4's, Blazers) and most pickups have 42.5", so you should check. Your driveshaft may be too long as well, and you know the 8 lug/6 lug thing is different, right?
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-30-2002, 01:02 PM   #4
Fast68Chevy
Fast68Chevy's Avatar
can do it if neither truck is a C30(1 ton) or all longhorn or a K5(blazer jimmy)
42.5" centers on all except 1 ton and blazer jimmy, and 40" centers n blazer jimmy and all 1 ton and all longhorn
U joint caps are 1 3/16" diameter on 3/4 ton and 1 ton and smaller on 1/2 ton, youll need universal u joint at the axle pinion yoke, you can also use a 73-up rear end if you relocate one of the shock mounts, axle tube U clamps wil be different
Fast68Chevy is offline   Reply With Quote
