02-15-2005, 07:08 PM | #1 |
1970 4X4 what to look for?
Long story, but I am probably going to be looking at a 70 4X4 1/2T over the weekend. What are things that are specific to this year that I should be looking for? I thought I read (on this board, where else?) that the '70 drums were an off year, and VERY hard to find/replace... Those are the kinds of things I'm looking for...
This isn't a truck I'm looking to keep, just helping somone out. So if there is interest, let me know about that also...
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
02-15-2005, 09:04 PM | #2 |
After reading the title of the post I was going to say the thing to look for is a 1971 or 1972. But I see you already know about the pre-71 front drum brakes.
If the 1970 is a keeper it isn't too hard to swap the front over to disk brakes. But I see you aren't going to keep it either. Soooo Look for rust in the usual places. Cab corners. Rockers. RF fender under the battery. Put the transfer case in 4 high and drive it around. Put in 4 low and drive it around. If its an automatic make sure it shifts ok. Make sure the VIN on the B-pillar matches the title and the partial VIN on the top of the frame between the power steering gear and the engine mount. If its AC equipped make sure the compressor turns on when you select AC.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
02-16-2005, 05:05 AM | #3 |
I moved this over here because we have a great bunch of guys that know their stuff with these old 4x4's. Hope it helps to get ya more answers.
02-17-2005, 04:13 AM | #4 |
Ttt
02-17-2005, 01:18 PM | #5 |
Chevys Kick A$$
mrein3 hit the nail on the head when he wrote all that stuff up above. If it has mud on it clean it off to make sure it is n't hiding any rust, and if can check out the eninge oil and stuff to make sure its all looking good.
Well since you already know about the brakes I can't think of anything off the top of my head for that year of truck. Good Luck! -Later
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
02-17-2005, 01:55 PM | #6 |
mrein3 & badbowtie - Thanks for the replies.
Hopefully I'll have pics Tuesday, and I'll think it over...
02-17-2005, 02:43 PM | #7 |
1969K10- Looking forward to seeing what condition it's in when you get it home. I've been looking for a 67-72 4x4 for a project. Please keep me updated if your selling it. Thank's Jason
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans. 2001 Chevy ZR2 Ext. cab 4x4 (DD) 1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process) 1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project) |
02-17-2005, 03:02 PM | #8 |
The windshield area is a good place and hard to fix area for rust. Check it out real well and while u are at it check the cowl area and down around the vents.
02-18-2005, 12:57 AM | #9 |
I believe its the 3/4 70 4x4 front drums that are hard to find..i think the 70 1/2 ton 4x4 ones are easier to find.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
