![]() ![]() Join Date: Jul 2002
Front Cradle Swap
The 82 is on it's way to a very quick death bed and not worht the bucks to put it right for the daughter. I'm thinking about doing the swap of the front cradle to get disks and 5 lug wheels, as well as the power steering. If I do the cradle swap, does it take everything, arms, spindles, tie rods, pitman, idler arm from the 82 or do I have to mix and match any of the 70 suspension with it?
If I go this route, I'll be using the 82 power steeriing also. I may also borrow the turbo 350 and latemodel rear end/brakes from it also.
if you use all the pcs from the 82, you should have it covered
you have to drill two holes in the frame but it is a great swap just leave the tires on and roll it out from the 82 and under your truck another person and a floor jack makes a lot easier
Drive fast and Take Chances - In memory of Todd Rowe #725 Fire Chief 96 Chevy K1500 67 Chevelle 70 Chevy C10 - Old Red |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Heck, I know a certain guy who doesn't even bother to drill those 2 holes sometimes. I..er...He just uses the other 12 bolts and doesn't worry about the last 2. Particularly if the truck has an engine in it, as that makes the drilling near impossible.
#5 | |
Bill...I always watch your post to see what you've done to your truck. Only difference is...mine is a GMC. Your post too Kevin....seems I always learn something when I read them....like going with only 12 bolts. Dunno if I want to do that....but if I keep the 6 cyl....it'd probably work just fine.
DECISIONS....DECISIONS!!!! *and Im a man who has to THINK which leg goes in the pants first* LOL Billy G
My FAMOUS LAST WORDS...."Ima Gonna!!" - 1970 GMC 1500 swb/step 250 I-6 3 spd - "The GEM" - 1976 Chev Scotsdale swb/step 350/350 - "The JEWEL" - 1982 Chev C-10 swb/step 250 I-6 3 spd - - 2001 Chev Silverado LT - |
![]() Join Date: Dec 2001
What happened to the '82?
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
That sounds like a great plant on updating your truck.
Are you still covered in pollen down there by the water, in south MS? I am ready for spring like weather to get to north MS. good luck with the conversion
ongoing 1970 c 10 lwb ![]() 1994 z-28 few mods.-owned since new ![]() 1978 vette silver/grey 25th anniv. paint ![]() |
Greasemonkey, besides the engine gasping for it's last, broke piston sleeve and a bad rod, The AC system went kaput (1000 bucks + right after the warrenty expired of course) and a few other things are acting up. It's going to take too much money to get it back as a reliable daily runner for my daughter, so time to cut loose. Not sure what I am going to do yet, except look for another truck for her.
#10 | |
Seņor Member
