Old 02-15-2005, 10:30 PM   #1
teamharvey
teamharvey's Avatar
Battery Cut-Off Switch Help
Where and how does this hook-up ?
Thanks,
Bret
71 Custom 20 Deluxe..soon to be SWB 1/2 ton
1 incredible wife
2 great kids
teamharvey is offline   Reply With Quote
Old 02-15-2005, 11:15 PM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
id imagine between the battery and the starter
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 02-15-2005, 11:34 PM   #3
72402
Positive cable to one side, cable from other side to starter solenoid.
72402 is offline   Reply With Quote
Old 02-16-2005, 12:02 AM   #4
J.Dirte
J.Dirte's Avatar
If you are using this to keep your battery from going dead while the truck is off, simply splice this in between the battery and the ground connection or the battery and the starter.
Keep in mind this switch will not shut down the engine in this configuration with the use of an alternator (that is wired like mine). It will run on the alternator... I found this out during the tech inspection at the dragstrip! To shut the engine down with this switch, you will either need a dual pole switch, or be sure that the alternator feeds the battery directly and the switch is between the battery and the source for the ignition power.
Clear as mud?
J.Dirte is offline   Reply With Quote
Old 02-16-2005, 12:25 AM   #5
teamharvey
teamharvey's Avatar
I wanted to use this as a cheap security system. I was curious if others had them and how they wired them in for convenient access.
1 incredible wife
2 great kids
Old 02-16-2005, 04:47 AM   #6
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Well if you splice into the large wire going from the battery to the starter you COULD use it as a "Cheap" anti-theft device.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
