good news
i dont know if any of you care or not but i got my spark plugs changed and put a stant superstat in my truck went over and turned the key and it fired right up first shot and ran like a champ. looks like the head gasket isnt blown. no water in the oil. no signs on the plugs and with the rad cap off it doesn't puff up through there either so i think im ok.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
Got Light Emitting Diode?
good luck
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
It's nice when a problem isn't as serious (or expensive) as was first thought
71 Chevy C10 "The Rust Bucket" 72 Chevy C10 apart in the garage 02 WS6 T/A Fast Black and bad@$$ 93 Nissan Pathfinder "Emily" Totaled RIP girl ![]() 05 Jeep Grand Cherokee-HEMI powered ![]() 87 Iroc Z28 305 TPI auto (crying out for an LS1 swap) |
now that's a good day! is there a thread that explains what happened to make you think you blew the hg?
'06 silverado (daily driver) '02 nissan sentra (wal-mart warrior) |
umm it's mentioned in a couple....basically my truck started running like crap....then it stalled and blew the bottom rad hose off. we thought it was puffing compression into the cooling system. everyone i talked to said check the plugs and see if one was clean because the water and antifreeze would steam clean one. i checked them and all the plugs were NASTY so i replaced the plugs put it all back together and everything looks ok
another thing about this motor...im sure my timing isnt perfect....my carb isnt setup right or anything...but i can go out there in 10 degree weather touch the key and it starts and idles
