Old 02-16-2005, 12:09 AM   #1
Daubs
Daubs's Avatar
Blowing fuses...where to start?
72 K20. Just home Sunday. Brakes did not work, nor did turn signals. Did have flashers in front and right rear. Got into the rear lights and dug around. Then blew "traffic hazzard" fuse. Oops.
Truck did not have fuse in the "tail stop / park dome" slot. I put one in and the dome light comes on. Press the brake and the dome dims...press brake four or five more times and blow the fuse.
I know I'm going to have to go through the wiring. Any suggesions on where to start?
'72 Chevy K-20 Crate 350, SM465, 4.10's
Daubs is offline   Reply With Quote
Old 02-16-2005, 12:12 AM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
you dont have a busted blug anywhere that could be touching ground, i blew some fuses that way
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 02-16-2005, 01:29 AM   #3
69 Short Fleet
I'd start by checking your brake light switch itself (may be faulty) and its wiring, next check or replace all main grounds, cab to frame, box to frame, ect and look closely at the rear wiring harness.
69 Short Fleet is offline   Reply With Quote
Old 02-19-2005, 12:43 AM   #4
Daubs
Daubs's Avatar
Found it -- Yellow wire got caught between frame and bolt. Grounding and shorting out fuses. Fixed her and my dome / taillights work well.
Turn signals don't "blink" but I think I'm on that. Thanks for the help.
