Old 02-16-2005, 04:31 AM   #1
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
LED install(PIC'S)
I installed a blinking red LED today.
69 Short Fleet(Doug) and I were discussing how to do this.So this is how it's done.
I know,I know...it's no substitute for a REAL alarm but this was real CHEAP and only took a couple hr's to do.
So here we go.
I started with a "blinking " red LED.It has the Blinking circiut and resistor built in so all you have to do is connect the "Anode" to a +12v source and the "Cathode" to ground.This was about $6.00 at my local electronics store(not Radio Shack)
Now that I had the flashing LED,the trick is to get it to flash while the truck is off and stop flashing when you turn the ign. on.
Well to accomplish this you simply use a common automotive relay.
I used a Single Pole Double Throw(SPDT) relay rated at 30amps.Way too much for my application but that's what I had on hand.Any amp rated relay will work though.
The actual draw that this circuit will use is in the mili-amps,not amps.
Here's the relay I used.Again about $5.00 at my local electronics shop.
So the next step was to decide where I wanted it mounted.
I did NOT want to drill into the face of the dash or the dash area between the front window and the dash pad,but that is where it would be MOST visable.
So I removed the drivers side air duct bezel and checked my clearances.Luckly things JUST fit.
I drilled a hole then mounted the LED retainer in the bezel.
I then slid the LED into the bezel and gave it a test.
Before installing the bezel back into the dash I "hot glued" the LED in place.
Now hooking up the LED with the relay was done exactly the same as you'd make the connections for ANY relay application.The ONLY difference is that I used the 87a terminal on the relay to connect to the LED.
The 87a terminal is "HOT" when the relay is not energized(relay not being triggered)
Normally the 87 terminal is used and becomes "HOT" when the relay is energized.
But in this application you want the operation of the relay to be opposite.
So this is how the relay is wired.
Here is the switched source I used for the 86 terminal.This terminal on the fuse box is only "HOT" when the ign. is on.
There is no power when the ign. is off or in the ACC. position.
I'm pointing to it with the tip of my circuit tester.
Then just find a constant 12v+ source and connect it to the 30 terminal.
Here it is back in the dash.
You really can't tell from the next few pic's but this LED is BRIGHT!
It blinks about once per second.
Anyhow,that's about it.
I now have a blinking red LED on my dash that will not protect my vehicle what-so-ever.
Thanks for listening
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 02-16-2005, 04:36 AM   #2
krue
Designated A-hole!
krue's Avatar
I like it! It will do about as much good as an alarm would.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 02-16-2005, 05:54 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've done this for years, into every car/truck I've had since the early 90's, and yes, it does deter would be thiefs.
However, there is an easier way to hook it up.
Take the positive, and hook it to a constant hot wire. Cigar lighter terminal is a good place.
Then take the negitave wire, and hook it to an ignition switched onr circuit, IGN unfused is a good place.
These take so little power, there is nothing wrong with pulling the cigar lighter wire off, and slipping the LED wire into the spaid connector, and back onto the terminal, and the same with the other wire.
The way that this works, the positive will be hot all the time, the ground circuit on the light will be interupted when ever you turn on the power, which will turn off the light. But when you kill the power (turn off the ignition) then the IGN UNFUSED is turned off, and esentually becomes a ground.
There is absolutly nothing wrong with doing the relay deal as dem onstrated above, however, this way is easier, quicker, cheaper...and I garuntee it will work.
Old 02-16-2005, 08:00 AM   #4
69 Short Fleet
Great thread Bobby!
69 Short Fleet is offline   Reply With Quote
Old 02-16-2005, 11:53 AM   #5
GreyHoundSteve
Nice detail, good post.
GreyHoundSteve is offline   Reply With Quote
Old 02-16-2005, 12:08 PM   #6
70c10
67-72 Addict!
70c10's Avatar
Nice post Bobby!
Andy- how do you attach the wires to the thin leads on the LED?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 02-17-2005, 02:49 AM   #7
muddpile
muddpile's Avatar
I did that on my old dodge charger with the positive to constant power and negative to the ignition. Worked great, except make sure not to wire it up sharing wires with your stereo, or it will turn the radio on at random when the vehicle is off. Believe me, I know from experience
muddpile is offline   Reply With Quote
Old 02-17-2005, 06:12 PM   #8
BobbyK
BobbyK's Avatar
70c10.Just solder wires to the anode and cathode ends.
Old 02-18-2005, 01:45 PM   #9
70c10
67-72 Addict!
70c10's Avatar
Thanks Bob!. That defroster idea was slick!
Jim
