02-16-2005, 10:58 AM | #1 |
Outragously over priced pieces of junk!
UPDATED!
I've finished restoring my '69. Need to make room for the '54. The parts below are from a 1969 C10 2wd short fleet side pickup with AC except where noted. Items are located in North Texas, 76273 shipping code. I also have a box full of small in-cab and in-door parts/brackets/hinges that I haven't listed. Feel free to ask me for anything. I can provide more pictures on request. I've priced everything pretty low from what I've seen on the board. I'm not so much interested in making money as to just get everything out of my shop. I don't do ebay. NEW ITEM: I forgot about this. cheyenne10 $75 - New black headliner in box. This is a $100 value. cheyenne10 $70 - New headliner trim in box. This is a $90 value. RARE ITEMS: Sold to Swbman $50 - Speed Warning Speedo with buzzer wire and adjustment cable. No buzzer. I've changed my mind on this rare option. The one I have procured seems to be missing a gear for the adjustment of the warning arm. It looks like it's been taken apart so I don't know if it works or not. I'm being up front about this so you won't get taken like I did. I will throw in the new wire for the buzzer and adjustment cable that I ordered. Maybe someone has another speedo where they can replace the missing gear. LARGE ITEMS: These items will need to be picked up locally in North Texas. $150 - AC Cab - Needs new rockers and floor. Includes cracked windshield and rear slider. Firewall and cowl area have been repaired with fiberglass in the past. The floor is rusted out to the point of seeing daylight but the supports are still solid. If I get no interest in cab, I will cut the ac dash out for someone. $40 - Driver side door. Has a 6x9 speaker hole cutout. Good shape no large dents or damage. Has holes for trim and mirrors. $20 - In-cab Fuel Tank Nothing wrong, moved to blazer tank. I will also throw in a brand new gromit. Keep on Truckin $20 - fuel gauge sending unit. $15 - drivers side swb rear fender - Only good for patch panels. Tail-light area is crunched and wheel arch is dented. $15 - steel front bumper. Lots of scratches but no twists or dents. $10 - seat frame. Good fold-able back frame. The bottom frame has been scavenged for a couple of springs. No foam or covers. SHIPPABLE ITEMS. cheyenne10 $70 - set of brand new chrome bumper guards. Some people call these bumperettes. $50 - 1/2 ton power brake booster. I can't verify that it works but it holds a vacuum. $20 - proportioning valve for 1/2 ton drum/drum brakes. $10 - windshield wiper motor - appears to be frozen up. These things are terribly over-priced when new. $20 - driver side vent window. black frame with clear glass. $10 - 4 whitespoke wagon wheels. $10 - pair of steel door panels. No covering. $10 - passenger side window glass. Clear with no big scratches. $5 - Window regulator - pass side. $5 - Window regulator - driver side. $15 - set of visors. Have been painted black. $10 - Inner and outer AC heater boxes - includes good heater core. Sold to biglou55 $30 - AC duct hoses s-duct, diverter box, ball and center vents and wiring harness. Sold to biglou55 $20 - AC/heater control. Top arm has busted and was N$@%@ rigged. Sold to biglou55 $10 - AC control cables. Set of 3 cables. Sold to Swbman $10 - under bed spare tire hanger. Sold to Putter $10 - NEW set of repo rocker panels. Never used. Sold to Smokie55 $10 - tail light wiring for short bed. Also have the clips. Sold to Smokie55 $10 - Front bumper brackets. 4 pcs. Very clean, have been primered. Sold to 71cadc10 $40 - set of wing vent windows. black frame with clear glass. Sold to 71cadc10 $10 - panhard bar. Sold to 71cadc10 $10 - driver side window glass. Clear with no big scratches. Sold to Curbstone Mech $10 - NEW rear trailing arm bushings. Sold to Putter $5 - NEW under hood lamp kit. Sold to Putter $5 - NEW Cigarette lighter in package. Wire not included. Sold to tnblazerk $5 - dash panel housing. Includes the housing, and bezel. No gauges. Act now to get the special busted, scratched, cracked and fogged plastic insert! FREE ITEMS. Any donations above the shipping costs will go to Josh for the board: 69ChevySWB -blue bowtie for hood. 69ChevySWB -C/10 350 emblems. 69ChevySWB -Ash tray with black face. Sold to Smokie55 -Set of backup lights /w lens. Sold to Smokie55 -Set of tail light housings with wiring harness. Sold to HuggerCST -set of arm rests. Sold to HuggerCST -set of seat belts. 71-longbed -license plate lamp bracket. Not factory. Sold to thexman10 -door striker plates. -inside door handles and cranks -67-68 emergency brake bracket plate. -67-68 clutch hanger bracket with petal. -Windshield wiper arms. -steering column brackets for firewall. Primered. -1/2 ton master cylinder for drum/drum. I have 2, need a core? -NEW Dust shields. 6pc rubber strips with hog rings. I have no clue where these go. -Accelerator bracket with arm. Not the cable style. -inside wiring harness. Includes... well, a bunch of wires. Was pulled from my daily driver but it has been hacked on some. The fuse holder is still good but one of the screw holes has broken off. It's been zip-tied for years with no problems.
'69 C/10 Short Wide 350/400/AC/Tilt/Tach Last edited by /<eystroke; 02-22-2005 at 11:39 AM. Reason: Updated buyers. |
02-16-2005, 10:59 AM | #2 |
More pictures.
'69 C/10 Short Wide 350/400/AC/Tilt/Tach |
02-16-2005, 11:00 AM | #3 |
Seat frame and fender.
02-16-2005, 11:09 AM | #4 |
I will take the speedwarning, I have got one I need to fix.Do you have pics. of spare tire holder,whats its condition are all pieces there.thanks....
02-16-2005, 11:10 AM | #5 |
Active Member
I'll take the trailing arm bushings. Let me know how to pay.
Thanks!
68 short fleet 383 stroker, 700r4 373:1 posi 72 GMC 3/4 ton- weekly driver 700r4 351;1 posi |
02-16-2005, 11:25 AM | #6 |
I'm interested in the black seatbelts and arm rests, but I didn't see a price. Did I miss it? Oh yea, put me next in line on the speedwarning if SWBMAN passes.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com Last edited by HuggerCST; 02-16-2005 at 11:30 AM. |
02-16-2005, 11:25 AM | #7 |
Is the tail light wiring new?? If so I'll take it.
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
02-16-2005, 11:26 AM | #8 |
I am interested in a few items. I have them listed below. please let me know if you still have them and how we can get together to swap out. I am in North Texas (Wylie).
- Tailight Wiring for Short Bed w/clips - $10.00 - Front Bumper Brackets 4 pcs. - $10.00 - Set of back up lights w/lenses - free - Set of tailight housing w/wiring harness - free Thank You, Will
-- Will Evans -- 1955 Short Step "Sweet Pea" - Family heirloom. 1969 Suburban "Otis" - 396/TH400 - Dallas Ambulance - 1972 K5 blazer "Rusty" - 400/TH350/NP205 - Yeah it's big alright!! - Founding Member of Southern Bowties Club - |
02-16-2005, 11:28 AM | #9 |
More Cowbell....
I will take the rocker panels ($10), the under hood lamp kit ($5), and the cigarette lighter ($5).
How do you want the money? Figure shipping (Jackson, MS 39212) and give me a total please. THANKS
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 02-16-2005 at 11:42 AM. |
02-16-2005, 11:38 AM | #10 |
User #12137
can i get a better pic of the woodgrain dash bezel please ? is there any cracks in it or busted anywhere ?
and how bout the black sun visers are they in good shape and a better pic of those to please ? and how much for them ? and how much to ship to 37664 ? Last edited by tnblazerk5; 02-16-2005 at 11:41 AM. |
02-16-2005, 11:44 AM | #11 |
I am interested in the Arm Rests/Seat Belts/350 Emblems/Bowtie/Ashtray. PM Sent.
Brian Thompson 99 2500 Silverado 6.0 05 Suburban (Wife's) 67 Mustang (Wife's) |
02-16-2005, 11:53 AM | #12 |
I can receive Paypal or money orders. PM me for details.
SWBman - PM sent. Curbstone Mech - Done. PM me for payment details. HuggerCST - I forgot to list the seatbelts. How about $30 for seatbelts, visors, and arm rests? Deuce - Tail light wiring is not new, but is in perfectly good working shape. Smokie55 - I'm in Whitesboro. PM me for details. Putter - done. PM sent. tnblazerk5 - I can get a better picture of the dash bezel tonight. I don't think it is cracked, but I know the chrome is peeling off of the plastic in places. The visors and arm rests are spoken for I think. 69ChevySWB - PMed.
02-16-2005, 11:57 AM | #13 |
User #12137
ok thanks so how much to ship the dash to 37664 ? and can i get in line for the visors
02-16-2005, 12:04 PM | #14 |
HuggerCST - I misread your post. How about $15 for seatbelts? Arm rests are free with donation.
tnblazerk5 - I can get a better picture of the dash bezel tonight. I don't think it is cracked, but I know the chrome is peeling off of the plastic in places. HTML Code:
<DEL>The visors and arm rests are spoken for I think.</DEL> I mised up the posts. The visors were originally green and have been spray painted black.
02-16-2005, 12:08 PM | #15 |
User #12137
i dont care about the chrome i was going to paint that part black anyway as long as the woodgrain and the peice itself are in good shape
02-16-2005, 12:11 PM | #16 |
/<eystroke- You didn't misread it, I edited my post after I reread your first post & saw that the visors were painted. I'll pass on them, but will take the belts & arm rests. Send me a total & how to pay shipped to 71227. Thanks
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
02-16-2005, 12:22 PM | #17 |
I am interested in the...
$30 - AC system heater box and duct work. Includes good heater core, inner and outer heater boxes, s-duct, diverter box, ball and center vents and wiring harness. See below for cables and control. $20 - AC/heater control. Top arm has busted and was N$@%@ rigged $10 - AC control cables. Set of 3 cables and put me inline for the armrests and visors if they aren't sold. What do you want for the inside door handles and window cranks?? Let's make a deal, shipping to 44663
71 Chevy Long Bed (gettin' bagged) 84 GMC K1500 (Sold) 85 Monte Carlo SS white w/gray int. (being a dumba** and totaled it ) 85 Monte Carlo SS clone T-top (Sold) 72 Chevelle-tubbed 64 Buick Sportwagon Last edited by wannabeburbowner; 02-16-2005 at 12:52 PM. |
02-16-2005, 12:31 PM | #18 |
Can I get a pic of the bumper guards and do thay have the mounting hardware?
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
02-16-2005, 12:48 PM | #19 |
put me in line for the same stuff wannabeburbowner wants. if he doesn,t take them. (box of a/c stuff-a/c controls and cables ) shipping to 01301.greenfield mass.
Certifiably crazy person |
02-16-2005, 01:08 PM | #20 |
Its Magically Delicious
im interested in any of these if still available .. shipping to 97302 ..thanks
$5 - NEW Cigarette lighter in package. Wire not included license plate lamp bracket. Not factory. Set of tail light housings with wiring harness.
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
02-16-2005, 01:09 PM | #21 | |
02-16-2005, 01:10 PM | #22 | |
There are no mounting hardware they fit directy over the bumper bolts. I don't have a better picture right now. They are in the box in the middle of the pile of parts I have above. I can get a better picture tonight. They are new and was never installed. Mine look like these except for not having the rubber pads.
02-16-2005, 01:17 PM | #23 | |
Just kidding. It's in good shape. Stiff but not cracking. It's rolled up in the picture. I rolled it up yesterday to take the picture and didn't notice any eccessive brittleness. I will look at it closer tonight to make sure. I ended up with two of these when I rebuilt my truck. I had a long bed and a short bed. I just grabbed one after I coated my frame and ended up using the longbed wire.
02-16-2005, 01:31 PM | #24 |
More Cowbell....
You have been PAID, sir. Thanks.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
02-16-2005, 04:05 PM | #25 |
Next in line for the wiring harness can have it. Thanks.
