02-16-2005, 01:06 PM | #1 |
Randy I need measurments
Could you measure the distance from the front axle center to the bottom of the front fender arch on your truck. You have a rancho 4 in lift on your truck and body lift to level it out right? just tryin to figure out my amount of lift in my 67 k10. I measured the 68 k20 i had and it only showed i had about 2.5 inches of lift. Just wanted to know.
(back not needed beacuse of flatbed on my truck) thanks
'67 chevy on '79 K10 frame Metallic Grey-Fleet White top 35in Ground Hawgs 355 ci, SM 465, NP 205 "A Dying Breed...Classic Chevy" |
02-16-2005, 01:33 PM | #2 |
I will try to get by there today. I dont keep my truck here. Sraight up from the hub to the bottom edge of the fender? If you wanna PM me your number and name I can call you when I get to work if I can get by there and get it.
02-17-2005, 04:11 AM | #3 |
From the center of the hub to the bottom edge of the fender straight up from the hub is about 31 inches.
