need opinions on blower scoop
motor is getting assembled now. trying to figure out how high i should mount the scoop. the first pics is how it will be mounted if i don't modify it. the last pics are how high i can go with it. i can add spacers between scoop and carbs to raise it up. and i can also add spcacers between the carbs to raise the carbs up too. mostly going for what will look best. keep in mind there will be some nicely polished carbs underneath it, not a wooden block, lol. let me know what you think.
67 Chevy SWB - goal of a 1,000 hp weekend cruiser Last edited by Oborny71; 02-16-2005 at 06:52 PM. |
graphic designer
are you really bent on cutting a hole in the hood? you're asking for opinions here, so i vote no hole.
well the blower won't fit under the stock hood. the carbs will fit under a 4" cowl hood, but i'd have to mount a remote aircleaner setup somehow to make it fit
67 Chevy SWB - goal of a 1,000 hp weekend cruiser |
no brain no headache
i like "as it sits"
1996 GMC Sierra z71 ![]() 1970 SWB 2wd (project) ![]() |
Keep the scoop as low as you can, it looks alot better low. Cut the hood, they only made a million of them.
One of my kids. Cute eh?
My thoughts are exactly as Randy's. Cut the hood and mount the scoop low.
Mike
If a kid asks where rain comes from, I think a cute thing to tell him is “God is crying.” And if he asks why God is crying, another cute thing to tell him is “Probably because of something you did. John 3:16 2006 Chevy HHR 2000 Dodge Durango 1985 Jeep CJ-7 1970 Chevy Pickup |
I like it low, plus it makes looking to the right easier. That truck is going to look good which ever way you go.
buy a cowl and hide it....save the original sheet metal and make the guy at the stop light figure out just what's under there the hard way.......
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
on a side note, I like the look of your steering wheel... Where did ya get it?
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
id leave it low-plenty of visual when its running-motor is going to be moving different than body.what size rims and tires ?are those surpremes?that truck is going to look nasty!and run as well,good luck
i forgot one thing your going to have trouble matching paint-might not be to bad if you have clear coat
68 C/10
Leave it low, gives it a sleeker look.
(2009) GMC Sierra Denali 6.2 AWD (67 C/10 fleetside SWB) (2018GMC Yukon Denali) Wifes Car |
#13 |
the shoop is goin to sit farter back to the firewall if your moter is in the v-8 position like my tullel ram i had trouble cutting the hood because i couldnt leave much on the back of the hood for ridgidity look how close the scoop is to the firewall on my tunnel ram -kyle
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door |
#14 |
Put it as high as you can, hide it and it looks like my truck, you got it, flaunt it, as far as the stock hood, there a dime a dozen. CUT IT!!!!!!!!!!
#15 |
graphic designer
i am so not the person to worry about cutting vintage tin! but i still wouldnt cut the hood, not for preservation, but for my tastes. i dig stealth. but that's why it's an opinion. bottom line is do what YOU like to YOUR truck. it might look cool and i'll change my mind!
#16 |
Why put all that money into a Bad Azz Blower motor and not show it off? Cut the hood and raise the scoop just until you see the polished carbs! It will make everyone stop and stare! And thats what ya want dont ya??
For every person with a spark of genius, There are a hundred with ignition trouble. ![]() |
#17 |
a dime a dozen? when's the last time you guys looked for a nice 67-68 hood? i like the stealth look....hide it under a cowl if you wanna show it you can....
#18 |
ok, i did a mock up on the small block in there now. it will be a 427 big block going in there, so it might sit up a tad higher. i think i'll leave it normal heigth. man it looks so bad ass in person! pics don't do it justice! can wait till new motor is in and the engine compartment is all cleaned up and everything is lookin good
![]() farside- steering wheel is a grant steering wheel. you can get them cheap, for like $25 bucks at oreillys. lloyd k - wheels are chrome supreme's 15x8, 15x10, 255/60 and 325/50.
#19 |
I say cut it, but I have all ready stood over a hood with drill in hand thinking I was nuts for cutting a good hood and that was after I found one to use instead of my original.
As special70gmc said its going to sit quit always back and I had to cut the bracing in the back to get it to clear, then plated and welded it up. It is also going to be at an angle so it will be higher in the front; I don’t know how different it is with a 69-72 hood compared to the 67 hood. I had to go with an 8-inch cowl to be able to clear the front air cleaner.
#20 |
Merciless Butcher
After going that far and spending all that hard earned cash on the motor......I vote to cut the hood....Show off the blower.
Your Bought And Sold....I Got Your Soul! |
#21 |
Listening since '86
I don't usually reply to the cut/no cut issue but this time I will add my two cents - CUT IT!! Like mentioned above, if you're going to have all that hardware, it would be a shame to hide it.
BTW - thanks for the "cockpit" view of the motor as well, quite a neat angle to take a picture.
2007 Saturn Aura - hey it WAS a GM product |
