Old 02-17-2005, 12:09 AM   #1
superchevy
Got big-block?
superchevy's Avatar
are '77 vent windows same as '81
Need to know if the vent windows and frames from a '77 will fit in an '81 door OK.
SC
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 02-17-2005, 10:22 AM   #2
Jonboy
Slots go on anything!
yes.
1974 Jimmy- 5.3/4L80e/NP241
Old 02-17-2005, 10:59 AM   #3
CHEVYJEFF
CHEVYJEFF's Avatar
I say no, i tried some from an 80 on my 90 blazer and they look similar but the radius of the curved part is diffrent.
http://members.cardomain.com/chevyjeff
57 2 DOOR HDTP
82 CORVETTE
90 V10 BLAZER
97 REGAL LSR 2100 (BOAT)
CHEVYJEFF is offline   Reply With Quote
Old 02-17-2005, 11:06 AM   #4
454_72_4X4
454_72_4X4's Avatar
I know there are 2 different styles of windows but I don't know when they changed.
I also think if you're changing the vent frames and all, (not just the glass), they will fit.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 02-17-2005, 12:59 PM   #5
Jonboy
Hmmm. I pulled a set from a 86 Blazer, and they went right in the doors of my 73. I know that they changed the weatherstrip a bit, but I am pretty sure the frame and all of the vent window is the same.
Old 02-17-2005, 03:07 PM   #6
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Vents will swap, they changed the frame and the glass in the later models. Also, the number of bolts required to secure it to the door changed in the same break as the doors.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 02-17-2005, 10:33 PM   #7
crossy
Oh,you can't buy that new
crossy's Avatar
73-80 or 81-87 , but never count on anything from an 81 NOT being like the 80- down style. You MUST change the entire thing though. the fasteners kaos is talking about is the small screws that go in from the top of the door frame , they went from 3 to 2 , but do line up if memory ,for once ,serves me . DAVE
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 02-18-2005, 12:09 AM   #8
f.monroe
f.monroe's Avatar
Vent windows
For some reason I want to say that the 81-81 side glasses are thinner than the 73-80 side glasses .That might cause an interference in the window channel. I think that is about the same time they went to the shorter (by about an inch ) vent windows. ?????????? Frank
f.monroe is offline   Reply With Quote
Old 02-18-2005, 12:27 AM   #9
CbHeEaVsYt
Pick up man
CbHeEaVsYt's Avatar
wat do u mean??????
cb
heres sum pics of my truck
82 silverado c10
heres my baby
1990 k1500
check out this 1957 chevrolet for sale
CbHeEaVsYt is offline   Reply With Quote
Old 02-18-2005, 06:50 AM   #10
crossy
crossy's Avatar
Frank, dats the facts- the 81-87 glass is indeed thinner. If you were to put the entire vent assembly from an 81-87 into a 73-80 door and assuming the window channel was almost new (NOT going to happen anymore) the thicker glass may encounter extra resistance. Ever notice that the after market only sells one channel to fit all years? with manual windows like most 73-80 have yul prolly never notice any difference,but with the power windows it may take a few days before the channel 'opens' wide.
FOR YEARS NOW- GM has only offered the newest style 90-91 as replacement, complete assemblies only and only in tinted. the 90-91 Blazer/Burb had more rubber that sealed to the outer doorshell in an effort to stop the nasty wind whistles. the last time I bought a whole assembly from GM they were about $135 ea. and that was 8-10 years ago.
CB- I owned at least two 1981's and other than the obvious sheetmetal differences from 1980 GM carried a lot of the 73-80 suspension & general hardware pieces. Never assume with an 81. I KNOW that my one SWB 81 had an 80 down frame that wasn't lightened up like the 82-87's. Not thickness wise but more the way of braces & brackets & such. both mine also had the thicker brake rotors. DAVE
98 Vortec project.
94,3500,6.5L 4L80
Old 02-18-2005, 07:57 PM   #11
Captkaos
Captkaos's Avatar
Ain't that the truth. Change over year for more than just sheetmetal. You get hit with different frame, axles, clusters.... Basically whatever GM had left over would still make a '81 truck, so whatever was there is what you got...
Chris Lucas
1973 Chevy C-10
Captkaos Customs
