02-17-2005, 01:12 AM | #1 |
72GMC51
carb return spring w/700r4
In the final stages of install of my 700r4, any sugestions on carb return springs. The TV cable is on the bottom of the throttle linkage were the throttle return spring would normally go on the Edelbrock carb I am using. Pictures would be nice. The throttle return on my 88 is built into the TBI on the pass side.
72 GMC 2wd 1/2 long 350 700r4 A/C PS PB 4:10. Are they ever really finished |
02-17-2005, 01:22 AM | #2 |
i ran my spring from the engine lift hook in front of the carb to a top hole in the linkage so it pulls it forward.
02-17-2005, 10:13 AM | #3 |
Got big-block?
You can go to Azone, PepBoys, etc and buy a $2 chrome throttle return spring bracket...just remove an intake bolt to the front of the carb, install bracket, and hook up spring...just like the engine lift bracket idea above, except a little flashier if you like.
SC
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
02-17-2005, 12:23 PM | #4 |
Check these two links out:
http://67-72chevytrucks.com/vboard/s...d.php3?t=70868 http://67-72chevytrucks.com/vboard/s...d.php3?t=70874 I had to go through this when I swapped out my old 2bbl carb to my new 4bbl setup. I had no kickdown before for my TH400, so I basically had to do a whole new setup. I'm not saying this is the best solution, but I can save people time who are thinking along these lines... You can get the throttle linkage separate from the Lokar kickdown. you don't have to commit to the kickdown switch to get the bracket. I believe it comes with springs, but you can get the springs separate if you want too.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
02-17-2005, 11:54 PM | #5 |
72GMC51
Thanks for the input, your sugestions got me thinking (thats when I usally get myself onto trouble) I fabricated a bracket and will go over to the shop tomorrow to have it made out of stainless plate the picture is not that good will post a new one when I get the plate done. Thanks Again.[IMG]
